소개
You will use this guide to replace the folding hinge in a Skullcandy Crusher Wireless headphones. Replacement folding hinges can be bought online or taken from another Skullcandy Crusher Wireless headphone.
필요한 것
다른 10명이 해당 안내서를 완성하였습니다.
댓글 7개
Hi, Like the explanation but can you tell me where to buy tge folding hinge?
I'm 3D printing these here https://www.ebay.co.uk/itm/364153346438
Stronger than original.
This is my alternative solution, albeit a temporary one. Sharing for people that end up here through search engines.
I figured out a temporary fix. I am posting this for others arriving here from search engines and the like. I assume OP's problem has long been solved. My fix is based on somebody else's fix.
I have 3D printed parts on the way, but my 'design' may actually press down on my ears better than the original. 🤔
What you'll need:
-Tie rip 2 mm
-Tie rip 4 mm
-Drill + 1,5 mm drillbit for metal
-Strong thin elastic.
-Pliers (for making sure the tierips are real tight.)
