주요 콘텐츠로 건너뛰기
Skullcandy Lowrider Wiring Repair
필요한 것
  1. Skullcandy Lowrider Wiring Repair, Repairing a Severed or Damaged Wire: 1 단계, 이미지 1/3 Skullcandy Lowrider Wiring Repair, Repairing a Severed or Damaged Wire: 1 단계, 이미지 2/3 Skullcandy Lowrider Wiring Repair, Repairing a Severed or Damaged Wire: 1 단계, 이미지 3/3
    • If your wire is severed, the first step is removing the rubber coating to expose both ends of the severed wire.
    • Do this by wedging it in a sharp crevice and pulling at the rubber coating. It should strip just the rubber coating. The small wedge in a spudger should suffice.
  2. Skullcandy Lowrider Wiring Repair: 2 단계, 이미지 1/2 Skullcandy Lowrider Wiring Repair: 2 단계, 이미지 2/2
    • Now that the internal wires have been exposed, take one end and group all similarly colored wires together.
    • Do the same for the other severed wire.
  3. Skullcandy Lowrider Wiring Repair: 3 단계, 이미지 1/3 Skullcandy Lowrider Wiring Repair: 3 단계, 이미지 2/3 Skullcandy Lowrider Wiring Repair: 3 단계, 이미지 3/3
    • Twist the green wires from both ends of the severed wire together.
    • Cover in electrical tape.
  4. Skullcandy Lowrider Wiring Repair: 4 단계, 이미지 1/1
    • Do the same for all matching wires on both ends.
    • Cover completely in electrical tape.
결론
Ryley
회원 가입일: 01/16/15
273 평판
안내서 3개 작성하였습니다
USF Sarasota-Manatee, Team 1-2, Stewart Winter 2015 USF Sarasota-Manatee, Team 1-2, Stewart Winter 2015 회원
USFSM-STEWART-W15S1G2
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 7
전체 시간: 625
