주요 콘텐츠로 건너뛰기
Skullcandy Mix Master DJ Mylar Driver Replacement
필요한 것
  1. Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: 1 단계, 이미지 1/3 Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: 1 단계, 이미지 2/3 Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: 1 단계, 이미지 3/3
    • With the plastic opening tool, separate the padded ear cup from the main speaker component.
    • Make sure to fold the ear cup inward to avoid getting in the way of the opposite side.
  2. Skullcandy Mix Master DJ Mylar Driver Replacement: 2 단계, 이미지 1/1
    • Using your screw driver, remove the six Philips 2mm screws located on the chrome ring.
  3. Skullcandy Mix Master DJ Mylar Driver Replacement: 3 단계, 이미지 1/2 Skullcandy Mix Master DJ Mylar Driver Replacement: 3 단계, 이미지 2/2
    • Using your screw driver, remove the four 3mm Phillips screws located on the grey speaker.
    • Remove the driver from the gray speaker assembly.
    • Carefully remove the driver assembly since there are wires connected to the headphone jack, headband, and mute button.
  4. Skullcandy Mix Master DJ Mylar Driver Replacement: 4 단계, 이미지 1/2 Skullcandy Mix Master DJ Mylar Driver Replacement: 4 단계, 이미지 2/2
    • Using your screw driver, remove the two 2mm Phillips screws located on the circuit panel of the audio jack.
    • Carefully separate the jack from the ear cup casing.
    • If you are working on the right ear cup, the mute button circuit board may be difficult to remove.
  5. Skullcandy Mix Master DJ Mylar Driver Replacement: 5 단계, 이미지 1/2 Skullcandy Mix Master DJ Mylar Driver Replacement: 5 단계, 이미지 2/2
    • The Mylar driver is connected to several small circuit boards by soldered wires. It can only be removed by cutting the connecting wires.
    • Do not pull the driver away too fast since there are wires connecting the driver to the ear cup.
    • Soldering Guide: https://www.youtube.com/watch?v=urGB_IUX...
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Sean Herlihy
회원 가입일: 03/30/15
117 평판
안내서 1개 작성함
UMass Dartmouth, Team 1-3, Shastany Spring 2015 UMass Dartmouth, Team 1-3, Shastany Spring 2015 회원
UMASSD-SHASTANY-S15S1G3
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 7
전체 시간: 1,487
