소개
If the device is having poor battery performance, consider replacing the battery of the Sky 6.0Q phone. The battery of the device only has a set performance life, and is more cost effective to replace that purchasing a completely new phone. The design of the Sky 6.0Q phone makes accessing the battery difficult, so it is necessary to be careful when removing the back plates and to not lose the small screws. It is recommended to use a magnetic work board to keep the screws from rolling away and are always on hand once the battery is replaced. Also, the battery itself is thin, so make sure to not tear or puncture it during removal. Lithium is toxic, so leaking of this on the phone or user can be dangerous.
필요한 것
Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
Pry off the back plate with the spudger.
다른 2명이 해당 안내서를 완성하였습니다.
