주요 콘텐츠로 건너뛰기
Sky 6.0Q Top Motherboard Replacement
필요한 것
  1. Sky 6.0Q Top Motherboard Replacement, Top Motherboard: 1 단계, 이미지 1/1
    • Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
    • Pry off the back plate with the spudger.
  2. Sky 6.0Q Top Motherboard Replacement: 2 단계, 이미지 1/1
    • After removing back panel, remove all ten 3mm screws with the #00 Phillips screwdriver from the black plastic casing so it can be removed.
  3. Sky 6.0Q Top Motherboard Replacement: 3 단계, 이미지 1/2 Sky 6.0Q Top Motherboard Replacement: 3 단계, 이미지 2/2
    • Use the plastic opening tool to help pry up the plastic backing.
    • Once loose, remove the plastic backing to expose underlying electronic components.
  4. Sky 6.0Q Top Motherboard Replacement: 4 단계, 이미지 1/1
    • Use the spudger disconnect the gold cord extending from the battery to the top electronic board.
  5. Sky 6.0Q Top Motherboard Replacement: 5 단계, 이미지 1/3 Sky 6.0Q Top Motherboard Replacement: 5 단계, 이미지 2/3 Sky 6.0Q Top Motherboard Replacement: 5 단계, 이미지 3/3
    • Use the nylon spudger to help pry up the three top motherboard attachments.
    • See all three pictures for three attachment locations.
    • To reattach top motherboard connections gently press piece back in place.
  6. Sky 6.0Q Top Motherboard Replacement: 6 단계, 이미지 1/1
    • Use the #00 Phillips screwdriver to remove the three 3 mm screws attaching the top motherboard.
  7. Sky 6.0Q Top Motherboard Replacement: 7 단계, 이미지 1/1
    • Once the screws are removed, gently lift the top motherboard and replace.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Monica Difato
회원 가입일: 11/06/18
429 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G3, Hovde Fall 2018 IUPUI, Team S1-G3, Hovde Fall 2018 회원
IUPUI-HOVDE-F18S1G3
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 13
전체 시간: 514
