주요 콘텐츠로 건너뛰기
Sky Thunder HD 8500WH Gear Replacement
필요한 것
  1. Sky Thunder HD 8500WH Gear Replacement, Rotor Blade: 1 단계, 이미지 1/3 Sky Thunder HD 8500WH Gear Replacement, Rotor Blade: 1 단계, 이미지 2/3 Sky Thunder HD 8500WH Gear Replacement, Rotor Blade: 1 단계, 이미지 3/3
    • Place the drone with the top side facing up.
    • Remove the blade cover.
    • Remove the rotor blade.
  2. Sky Thunder HD 8500WH Gear Replacement, Lockstitch: 2 단계, 이미지 1/2 Sky Thunder HD 8500WH Gear Replacement, Lockstitch: 2 단계, 이미지 2/2
    • Unscrew the 1cm screw holding in the blade lockstitch with the Phillips 0 Screwdriver.
    • Remove the blade lockstitch.
  3. Sky Thunder HD 8500WH Gear Replacement, Lower and Upper Body: 3 단계, 이미지 1/3 Sky Thunder HD 8500WH Gear Replacement, Lower and Upper Body: 3 단계, 이미지 2/3 Sky Thunder HD 8500WH Gear Replacement, Lower and Upper Body: 3 단계, 이미지 3/3
    • Lay down the drone so the battery side is facing up.
    • Unscrew all 5 .8cm screws on each arm of the drone with the Phillips 0 Screwdriver.
    • Repeat previous bullet for each arm (20 screws in total).
  4. Sky Thunder HD 8500WH Gear Replacement: 4 단계, 이미지 1/2 Sky Thunder HD 8500WH Gear Replacement: 4 단계, 이미지 2/2
    • Using a bit of force, gently pull apart the lower and upper bodies.
    • Keep going until both parts are completely separated.
  5. Sky Thunder HD 8500WH Gear Replacement, Gear: 5 단계, 이미지 1/2 Sky Thunder HD 8500WH Gear Replacement, Gear: 5 단계, 이미지 2/2
    • Find the gear mechanism at the end of one of the drone arms.
    • Unscrew the two front .8cm screws with the Phillips 0 Screwdriver.
  6. Sky Thunder HD 8500WH Gear Replacement: 6 단계, 이미지 1/2 Sky Thunder HD 8500WH Gear Replacement: 6 단계, 이미지 2/2
    • Remove the white spacer.
    • Remove the red spacer.
  7. Sky Thunder HD 8500WH Gear Replacement: 7 단계, 이미지 1/1
    • Pull the gear out from the bottom of the holding mechanism.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nicholas Jones
회원 가입일: 09/25/17
672 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 141
