주요 콘텐츠로 건너뛰기
Skytex SP728 Case Replacement
필요한 것
  1. Skytex SP728 Case Replacement, Case: 1 단계, 이미지 1/1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Case Replacement: 2 단계, 이미지 1/1
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Case Replacement: 3 단계, 이미지 1/1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Case Replacement: 4 단계, 이미지 1/1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
결론
To reassemble your device with a new case, follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
Michelle Strickland
회원 가입일: 01/21/15
280 평판
안내서 2개 작성하였습니다
USF Tampa, Team 5-1, Brown Winter 2015 USF Tampa, Team 5-1, Brown Winter 2015 회원
USFT-BROWN-W15S5G1
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 3
전체 시간: 122
