주요 콘텐츠로 건너뛰기
Skytex SP728 Speakers Replacement
필요한 것
  1. Skytex SP728 Speakers Replacement, Case: 1 단계, 이미지 1/1
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Speakers Replacement: 2 단계, 이미지 1/1
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Speakers Replacement: 3 단계, 이미지 1/1
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Speakers Replacement: 4 단계, 이미지 1/1
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Speakers Replacement, Speakers: 5 단계, 이미지 1/1
    • Identify the connection location of the wires from the speakers.
  6. Skytex SP728 Speakers Replacement: 6 단계, 이미지 1/1
    • Use a soldering iron to remove the speaker wires from the circuit board
  7. Skytex SP728 Speakers Replacement: 7 단계, 이미지 1/1
    • Solder the new speakers to the correct location, making sure the red wire goes to the + and the black wire goes to the -.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chris Nelson
회원 가입일: 01/21/15
213 평판
안내서 2개 작성하였습니다
USF Tampa, Team 5-1, Brown Winter 2015 USF Tampa, Team 5-1, Brown Winter 2015 회원
USFT-BROWN-W15S5G1
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 101
