주요 콘텐츠로 건너뛰기
SleepTracker Elite Battery Replacement
필요한 것
  1. SleepTracker Elite Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 SleepTracker Elite Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 SleepTracker Elite Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • You will need:
    • CR 2032 Battery
    • Philips #0 screwdriver
    • Something to pop the battery out, like a thin spudger, or a #2 slot screwdriver.
  2. SleepTracker Elite Battery Replacement: 2 단계, 이미지 2개 중 1개 SleepTracker Elite Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Remove these four screws. They're all the same size.
  3. SleepTracker Elite Battery Replacement: 3 단계, 이미지 2개 중 1개 SleepTracker Elite Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Lift off the case back.
    • Underneath, you'll see a sheet of plastic film. It should be possible to remove the battery without removing the film, if you're careful, but I didn't want to risk bending or tearing the plastic.
    • If you do take the plastic off, beware of maneuvering it over the three springs in the upper left, and the small prong that sticks out over the battery. You'll need to be sure to arrange the plastic carefully over these obstructions when re-assembling.
  4. SleepTracker Elite Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Insert spudger or flat screwdriver in the notch indicated by the arrow, and lever out the battery.
    • The new battery should insert the same way the old one came out, and snap into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mark Boszko
회원 가입일: 02/02/12
131 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 1,305
