주요 콘텐츠로 건너뛰기
Sliding Folding Door Hinge Replacement
필요한 것
  1. Sliding Folding Door Hinge Replacement, Hinge: 1 단계, 이미지 1/1
    • Using the Phillips #2 screwdriver, remove any remaining old screws and hinges that you want to replace.
    • Counterclockwise will remove the screws.
  2. Sliding Folding Door Hinge Replacement: 2 단계, 이미지 1/1
    • Screws come loose when the holes become too large for the screws. If necessary, drill new holes into the door.
    • In this case, the top two holes were no longer usable, so we created more underneath the bottom holes.
  3. Sliding Folding Door Hinge Replacement: 3 단계, 이미지 1/2 Sliding Folding Door Hinge Replacement: 3 단계, 이미지 2/2
    • One by one, use the screwdriver to place the new screws.
    • The screws shouldn't be too tight. Be sure that the hinge is loose enough to rotate while placing the other screws.
    • Tighten all screws best you can with the hand held screwdriver.
  4. Sliding Folding Door Hinge Replacement: 4 단계, 이미지 1/1
    • The new hinge and screws should be in place now. If you would like, you can patch up the old holes and paint over them.
결론
Torianna Marasco
회원 가입일: 03/15/21
124 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 20
전체 시간: 724
