주요 콘텐츠로 건너뛰기
Small Engine Recoil Starter Replacement
필요한 것
  1. Small Engine Recoil Starter Replacement, Recoil Starter: 1 단계, 이미지 1/1
    • To begin the repair remove the protective casing. (This removal may vary with different lawnmowers.)
  2. Small Engine Recoil Starter Replacement: 2 단계, 이미지 1/1
    • Locate the recoil housing cap.
  3. Small Engine Recoil Starter Replacement: 3 단계, 이미지 1/1
    • Carefully remove the housing cap. (Removal may vary)
  4. Small Engine Recoil Starter Replacement: 4 단계, 이미지 1/1
    • After removing the recoil, unscrew the cap that holds the pulley to the recoil starter housing.
  5. Small Engine Recoil Starter Replacement: 5 단계, 이미지 1/1
    • Untie the knot in the rope and slide it out of the housing.
  6. Small Engine Recoil Starter Replacement: 6 단계, 이미지 1/1
    • With this particular model there is a middle lock piece. Use a socket wrench to unscrew and release the coil.
  7. Small Engine Recoil Starter Replacement: 7 단계, 이미지 1/1
    • Once unscrewed, remove the metal piece which releases the tension on the coil.
  8. Small Engine Recoil Starter Replacement: 8 단계, 이미지 1/1
    • At this point add the new coil to the housing base. Snap the coil into position where the old on was.
결론
다른 5명이 해당 안내서를 완성하였습니다.
James Marmaud
회원 가입일: 03/20/17
276 평판
안내서 1개 작성함
Missouri Western, Team S40-G16, Kunkel Spring 2017 Missouri Western, Team S40-G16, Kunkel Spring 2017 회원
MWSU-KUNKEL-S17S40G16
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 48
전체 시간: 2,779
