주요 콘텐츠로 건너뛰기
Smart Parts Ion Macroline Replacement
  1. Smart Parts Ion Macroline Replacement, Hopper and the Air Tank: 1 단계, 이미지 3개 중 1개 Smart Parts Ion Macroline Replacement, Hopper and the Air Tank: 1 단계, 이미지 3개 중 2개 Smart Parts Ion Macroline Replacement, Hopper and the Air Tank: 1 단계, 이미지 3개 중 3개
    • Remove the air tank by rotating it counterclockwise.
    • Do not pull the trigger or jostle the gun, there will still be pressurized air inside the gun that could be expelled and cause bodily harm if injected into eyes and/or skin.
    • The pressure gauge will indicate the leftover air in the gun.
  2. Smart Parts Ion Macroline Replacement: 2 단계, 이미지 2개 중 1개 Smart Parts Ion Macroline Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the hopper by pulling it out of the feed tube, located on the top of the body. The hopper should easily come off when pulled straight up.
  3. Smart Parts Ion Macroline Replacement, Smart Parts Ion De-Gassing: 3 단계, 이미지 1개 중 1개
    • Turn the gun on by pressing the power button until the red light blinks.
    • Turn vision mode off by pressing the power button again.
    • Red light should be flashing in a double blink sequence.
  4. Smart Parts Ion Macroline Replacement: 4 단계, 이미지 1개 중 1개
    • Pull the trigger to release the air in the gun.
    • Pressurized air can be forceful, causing particles to be ejected from the gun into your eyes and/or skin. When air bubbles enter the bloodstream, they can block blood vessels, causing embolisms. To avoid this, make sure to point the gun in a safe direction when pulling the trigger because air will be released from the gun.
  5. Smart Parts Ion Macroline Replacement, Macroline: 5 단계, 이미지 3개 중 1개 Smart Parts Ion Macroline Replacement, Macroline: 5 단계, 이미지 3개 중 2개 Smart Parts Ion Macroline Replacement, Macroline: 5 단계, 이미지 3개 중 3개
    • Push the metal fitting inwards and pull out the black tube. Repeat on the other side.
결론
작성자
4다른 기여자 명과 함께
Shane Villalpando
회원 가입일: 02/02/15
1,031 평판
안내서 10개를 작성함
Cal Poly, Team 8-42, Amido Winter 2015 Cal Poly, Team 8-42, Amido Winter 2015 회원
CPSU-AMIDO-W15S8G42
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 10
전체 시간: 1,759
