주요 콘텐츠로 건너뛰기
Smart Tweezers and LCR-Reader LCR-meter Screen Replacement
필요한 것
  1. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Opening the device: 1 단계, 이미지 2개 중 1개 Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Opening the device: 1 단계, 이미지 2개 중 2개
    • Start by removing the 4 screws in the back of the device using a size 00 Philips screw driver.
  2. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Replacing the screen: 2 단계, 이미지 2개 중 1개 Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Replacing the screen: 2 단계, 이미지 2개 중 2개
    • Gently open the zif connector that holds the screen.
    • Insert the replacement screen, and close the zif
  3. Smart Tweezers and LCR-Reader LCR-meter Screen Replacement, Closing the device: 3 단계, 이미지 1개 중 1개
    • When closing the housing, make sure the screen fits into the rectangle on the top.
    • If the screen is not in this rectangle, it may become damaged when the screws are tightened
    • Hold the screen in place from below; line up the button's edge of the top housing to line up with the bottom housing. Slide your finger out as you bring the top and bottom housings to meet.
    • Replace the 4 Philips screws in the back.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
brittany
회원 가입일: 07/16/12
234 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 552
