주요 콘텐츠로 건너뛰기
Smart Tweezers and LCR-Reader LCR-meter Tweezer Probes Replacement
필요한 것
  1. Smart Tweezers and LCR-Reader LCR-meter Tweezer Probes Replacement, Removing the old tips: 1 단계, 이미지 1개 중 1개
    • Start by removing the old tips with a T8 Torx screw driver.
    • Keep the screws and washers
  2. Smart Tweezers and LCR-Reader LCR-meter Tweezer Probes Replacement, Cleaning and replacing the tips: 2 단계, 이미지 2개 중 1개 Smart Tweezers and LCR-Reader LCR-meter Tweezer Probes Replacement, Cleaning and replacing the tips: 2 단계, 이미지 2개 중 2개
    • After the tips have been removed, it is best to wipe down the arms with isopropyl. This will ensure there are no debris in the way which may cause false readings.
    • Replace the tips using the washers and screws from the old set. If the device shows a reading while not in contact with anything, remove the tips, clean them and the arms again, and replace.
결론
If the device is showing a false reading, remove the tips and clean again.
작성자
2다른 기여자 명과 함께
brittany
회원 가입일: 07/16/12
234 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 3
전체 시간: 605
