주요 콘텐츠로 건너뛰기
SmartNav 4 false contact repair
필요한 것
  1. SmartNav 4 false contact repair, Device  dissasembly: 1 단계, 이미지 1/3 SmartNav 4 false contact repair, Device  dissasembly: 1 단계, 이미지 2/3 SmartNav 4 false contact repair, Device  dissasembly: 1 단계, 이미지 3/3
    • Gently open the four tabs with a small flathead screwdriver.
    • Carefully remove the black and silver cover.
  2. SmartNav 4 false contact repair: 2 단계, 이미지 1/2 SmartNav 4 false contact repair: 2 단계, 이미지 2/2
    • After detaching the two parts.
    • Unscrew the four hex screws with the 2mm hex key.
  3. SmartNav 4 false contact repair: 3 단계, 이미지 1/3 SmartNav 4 false contact repair: 3 단계, 이미지 2/3 SmartNav 4 false contact repair: 3 단계, 이미지 3/3
    • Remove and separate the components
    • The problem is caused by the black insulating film between the two boards which appears to be pierced through.
  4. SmartNav 4 false contact repair: 4 단계, 이미지 1/1
    • Remove the insulator, if present.
  5. SmartNav 4 false contact repair: 5 단계, 이미지 1/3 SmartNav 4 false contact repair: 5 단계, 이미지 2/3 SmartNav 4 false contact repair: 5 단계, 이미지 3/3
    • Prepare new divider. I used a 0.4mm rigid piece of plastic.
    • You can use a rigid piece of plastic, very thin (e.g. 0.4mm)
    • Take measurements and fit it.
  6. SmartNav 4 false contact repair: 6 단계, 이미지 1/3 SmartNav 4 false contact repair: 6 단계, 이미지 2/3 SmartNav 4 false contact repair: 6 단계, 이미지 3/3
    • Remake the device. Following the guide in reverse.
결론
To re-assemble your device, follow the steps in reverse order.
다른 2명이 해당 안내서를 완성하였습니다.
다음 번역가들에게 특별히 감사 드립니다:
it en
100%
이 번역자 분들은 저희가 세상을 수리하는데 동참해 주시는 분입니다! 기여하시겠습니까?
번역 시작하기 ›
Stefano Ficacci
회원 가입일: 05/27/16
166 평판
안내서 1개 작성함
댓글 2개
Has anyone ever able to fix the issue with the smartnav not powering on
Shane Agnew - 답글
I can give only the basic level of suggestions here.
The device is not responding at all, this is the situation I'm considering here, which means: no lights and no reaction from the computer when it is connected.
You should check first the cable and the computer port, this can be done with a different cable and a different port and/or with a different device on the same cable and port, better both methods.
Once you are sure that the cable and the port are good, you need to disassemble the unit, and you may need a tester for voltage and continuity.
A visual check will tell you if there are clear signs of problems such as cracks, rust or damaged components.
Chances are that the problem is in a faulty contact (the usb connector to begin with) but it still can be a defective component (the capacitors in this case).
From here on you may need to test the power supply to the ic circuit, without short circuiting other components with the probes.
A soldering unit could be necessary then.
Stefano Ficacci - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 11
30일 전: 15
전체 시간: 1,267
