주요 콘텐츠로 건너뛰기
Smartab STJR700 Back Camera Lens Replacement
필요한 것
  1. Smartab STJR700 Back Camera Lens Replacement, Back Camera Lens: 1 단계, 이미지 2개 중 1개 Smartab STJR700 Back Camera Lens Replacement, Back Camera Lens: 1 단계, 이미지 2개 중 2개
    • First, use a screwdriver to remove the screws on the back cover of the Smartab.
    • Next, carefully remove the cover to reveal the inside of the tablet.
  2. Smartab STJR700 Back Camera Lens Replacement: 2 단계, 이미지 3개 중 1개 Smartab STJR700 Back Camera Lens Replacement: 2 단계, 이미지 3개 중 2개 Smartab STJR700 Back Camera Lens Replacement: 2 단계, 이미지 3개 중 3개
    • When you open the tablet, you will see several components.
    • You will see that the camera is stabilized by screws. The digitizer is held in place using black tape.
    • When the black tape is peeled back, you will see that the digitizer is also connected to the motherboard.
  3. Smartab STJR700 Back Camera Lens Replacement: 3 단계, 이미지 3개 중 1개 Smartab STJR700 Back Camera Lens Replacement: 3 단계, 이미지 3개 중 2개 Smartab STJR700 Back Camera Lens Replacement: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use a screwdriver to unscrew the camera from the tablet.
    • Use tweezers to remove the digitizer from the hard drive.
    • After the digitizer is removed and the camera is unscrewed, remove them from the tablet.
    • Replace the old camera with a replacement camera by using a screwdriver. Replace the old digitizer with a replacement digitizer by using a soldering tool.
    • To replace the camera lens, start by removing the broken glass by using tweezers.
    • If the new lens has adhesive, make sure that all the old adhesive is removed from the frame so that the lens does not stick out, and so a tighter seal is formed.
    • Once the glass is removed, place the new camera lense by peeling off the upper film and align the glass with the ring.
결론
작성자
6다른 기여자 명과 함께
Fatu Woodson
회원 가입일: 03/08/17
101 평판
안내서 1개를 작성함
UMass Dartmouth, Team S3-G4, Botvin Spring 2017 UMass Dartmouth, Team S3-G4, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S3G4
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 13
전체 시간: 457
