주요 콘텐츠로 건너뛰기
Smartab STJR700 Charging Port Replacement
필요한 것
  1. Smartab STJR700 Charging Port Replacement, Charging Port: 1 단계, 이미지 1/1
    • Power off the device by holding down the lock button. Remove the case from the tablet and place it face down.
  2. Smartab STJR700 Charging Port Replacement: 2 단계, 이미지 1/1
    • Unscrew all four corner screws using the PH000 screwdriver head found in the iFixit kit.
  3. Smartab STJR700 Charging Port Replacement: 3 단계, 이미지 1/1
    • CAUTION: Avoid touching the display.
    • Pry open the tablet using a metal spudger. Set aside the back panel.
  4. Smartab STJR700 Charging Port Replacement: 4 단계, 이미지 1/1
    • Locate the charging port.
  5. Smartab STJR700 Charging Port Replacement: 5 단계, 이미지 1/2 Smartab STJR700 Charging Port Replacement: 5 단계, 이미지 2/2
    • Unscrew all the labeled screws using the PH000 screwdriver head.
  6. Smartab STJR700 Charging Port Replacement: 6 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove all pieces of tape using the tweezers provided in the iFixit kit.
    • Remove the two ribbon cables affixed to the camera.
  7. Smartab STJR700 Charging Port Replacement: 7 단계, 이미지 1/1
    • Remove the motherboard component from the screen and display.
    • Because the charging port is soldered onto the motherboard, the motherboard must be replaced by one specifically made for the Smartab STJR700.
결론
Thi Le
회원 가입일: 03/08/17
101 평판
안내서 1개 작성함
UMass Dartmouth, Team S3-G4, Botvin Spring 2017 UMass Dartmouth, Team S3-G4, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S3G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 996
