주요 콘텐츠로 건너뛰기
Smartab STJR700 Home Button Replacement
필요한 것
  1. Smartab STJR700 Home Button Replacement, Home Button: 1 단계, 이미지 1/2 Smartab STJR700 Home Button Replacement, Home Button: 1 단계, 이미지 2/2
    • Power off device. Place it face down. Unscrew the four perimeter screws using a PH000.
  2. Smartab STJR700 Home Button Replacement: 2 단계, 이미지 1/1
    • Using a plastic opening tool or metal spudger, begin to gently pry the rear case down and away from the display. Slowly wiggle the tool up and down to pry open the tablet. Once the rear case is fully removed, place it to the side.
  3. Smartab STJR700 Home Button Replacement: 3 단계, 이미지 1/3 Smartab STJR700 Home Button Replacement: 3 단계, 이미지 2/3 Smartab STJR700 Home Button Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using tweezers, carefully remove the tape that is holding the black and red intertwined cables to the motherboard. Place tape to the side as it will be needed for reassembly.
  4. Smartab STJR700 Home Button Replacement: 4 단계, 이미지 1/1
    • Remove the two Phillips #000 screws holding the home button board to the front panel.
  5. Smartab STJR700 Home Button Replacement: 5 단계, 이미지 1/2 Smartab STJR700 Home Button Replacement: 5 단계, 이미지 2/2
    • Using tweezers, slowly and carefully remove the end of the cable that connects the home button to the main motherboard.
결론
To ensure a successful replacement make sure to follow all steps carefully .
Moriah Wiggins
회원 가입일: 03/08/17
201 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S3-G4, Botvin Spring 2017 UMass Dartmouth, Team S3-G4, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S3G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 305
