주요 콘텐츠로 건너뛰기
Smartab STJR700 Screen/Digitizer Replacement
필요한 것
  1. Smartab STJR700 Screen/Digitizer Replacement, Screen/Digitizer: 1 단계, 이미지 2개 중 1개 Smartab STJR700 Screen/Digitizer Replacement, Screen/Digitizer: 1 단계, 이미지 2개 중 2개
    • There are four screws with each one in each corner. Use the screwdriver to unscrew the back or bottom of the device.
  2. Smartab STJR700 Screen/Digitizer Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the bottom or back of the device by detaching the black bottom after removing the screws.
    • the front panel should now be exposing the digitizer along with the other electronic components of the device.
  3. Smartab STJR700 Screen/Digitizer Replacement: 3 단계, 이미지 2개 중 1개 Smartab STJR700 Screen/Digitizer Replacement: 3 단계, 이미지 2개 중 2개
    • Next, remove the circuit board from the front panel and screen. This should leave the digitizer and circuit board intact.
    • Afterward, remove the existing damaged glass part of the device from the front panel as shown in the last picture.
    • Finally add a new STJR700 screen and reverse the previous steps to reattach the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Tianna Edwards
회원 가입일: 03/22/17
128 평판
안내서 1개를 작성함
UMass Dartmouth, Team S3-G4, Botvin Spring 2017 UMass Dartmouth, Team S3-G4, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S3G4
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 4
전체 시간: 1,261
