주요 콘텐츠로 건너뛰기
Smartab STJR700 Speakers Replacement
필요한 것
  1. Smartab STJR700 Speakers Replacement, Speakers: 1 단계, 이미지 1/3 Smartab STJR700 Speakers Replacement, Speakers: 1 단계, 이미지 2/3 Smartab STJR700 Speakers Replacement, Speakers: 1 단계, 이미지 3/3
    • Power off device. Place it face down. Unscrew the 4 perimeter screws, using a PH000 screwdriver from iFixit kit
  2. Smartab STJR700 Speakers Replacement: 2 단계, 이미지 1/1
    • Using a plastic opening tool or metal spudger, begin to gently pry the rear case down and away from the display.Slowly wiggle the tool up and down to pry open the tablet.Once the rear case is fully removed place it to the side.
  3. Smartab STJR700 Speakers Replacement: 3 단계, 이미지 1/3 Smartab STJR700 Speakers Replacement: 3 단계, 이미지 2/3 Smartab STJR700 Speakers Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Using tweezers carefully remove tape that is holding the black and red intertwined cables to the motherboard. Place tape to the side as is will be needed for reassembly.
  4. Smartab STJR700 Speakers Replacement: 4 단계, 이미지 1/1
    • Remove the 2 screws holding the speaker to the front panel. Use a PH000 screwdriver from iFixit kit. Place the screws to the side as they will be needed for reassembly.
  5. Smartab STJR700 Speakers Replacement: 5 단계, 이미지 1/1
    • Use the metal spudger to remove the speaker from the front panel of the tablet.
  6. Smartab STJR700 Speakers Replacement: 6 단계, 이미지 1/1
    • Disconnect black and red intertwined wire from the motherboard.
결론
Moriah Wiggins
회원 가입일: 03/08/17
201 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S3-G4, Botvin Spring 2017 UMass Dartmouth, Team S3-G4, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S3G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 196
