주요 콘텐츠로 건너뛰기
Snapfōn ezONE LCD Screen Replacement
필요한 것
  1. Snapfōn ezONE LCD Screen Replacement, Remove the battery cover: 1 단계, 이미지 1개 중 1개
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Snapfōn ezONE LCD Screen Replacement, Remove the battery: 2 단계, 이미지 1개 중 1개
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
  3. Snapfōn ezONE LCD Screen Replacement, Removing the plastic inserts: 3 단계, 이미지 2개 중 1개 Snapfōn ezONE LCD Screen Replacement, Removing the plastic inserts: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the four rubber inserts from the screw holes using a pair of tweezers.
  4. Snapfōn ezONE LCD Screen Replacement, Remove the shield screws: 4 단계, 이미지 3개 중 1개 Snapfōn ezONE LCD Screen Replacement, Remove the shield screws: 4 단계, 이미지 3개 중 2개 Snapfōn ezONE LCD Screen Replacement, Remove the shield screws: 4 단계, 이미지 3개 중 3개
    • Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
  5. Snapfōn ezONE LCD Screen Replacement, Separate the case: 5 단계, 이미지 3개 중 1개 Snapfōn ezONE LCD Screen Replacement, Separate the case: 5 단계, 이미지 3개 중 2개 Snapfōn ezONE LCD Screen Replacement, Separate the case: 5 단계, 이미지 3개 중 3개
    • Separate the front case from the back case.
    • Remove the metal bumper from the front case’s perimeter.
  6. Snapfōn ezONE LCD Screen Replacement, Remove the volume slider: 6 단계, 이미지 1개 중 1개
    • Pry the volume slider button out with tweezers.
    • The volume slider button may fall out during the separation of the front and back cases. This is OK.
  7. Snapfōn ezONE LCD Screen Replacement, Remove the motherboard: 7 단계, 이미지 3개 중 1개 Snapfōn ezONE LCD Screen Replacement, Remove the motherboard: 7 단계, 이미지 3개 중 2개 Snapfōn ezONE LCD Screen Replacement, Remove the motherboard: 7 단계, 이미지 3개 중 3개
    • Separate the circuit board from the inside of the back case by prying between them with the opening tool.
    • The last picture is a view of the back of the circuit board.
  8. Snapfōn ezONE LCD Screen Replacement, Pry the screen back: 8 단계, 이미지 3개 중 1개 Snapfōn ezONE LCD Screen Replacement, Pry the screen back: 8 단계, 이미지 3개 중 2개 Snapfōn ezONE LCD Screen Replacement, Pry the screen back: 8 단계, 이미지 3개 중 3개
    • Pry the LCD screen off of the circuit board using the opening tool. The screen is connected to the motherboard with light adhesive, which is easy to remove.
    • The LCD screen will still be connected to the circuit board by a ribbon cable.
  9. Snapfōn ezONE LCD Screen Replacement, Disconnect the display: 9 단계, 이미지 1개 중 1개
    • Use a soldering iron to melt away the connection between the ribbon cable and circuit board.
    • Be careful! High temperatures from the soldering iron may result in injury.
    • Only make contact with the solder connection so that none of the phone’s components are damaged by the heat.
  10. Snapfōn ezONE LCD Screen Replacement, Remove the display: 10 단계, 이미지 2개 중 1개 Snapfōn ezONE LCD Screen Replacement, Remove the display: 10 단계, 이미지 2개 중 2개
    • Once you heat the solder connection, lightly tug the ribbon cable free. The LCD screen will be completely removed from the device.
결론
To reassemble your device with a new LCD screen, follow these instructions in reverse order.
Note: you will need to use the soldering iron again to attach the new LCD screen ribbon to the circuit board.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
John Bender
회원 가입일: 03/26/14
818 평판
안내서 8개를 작성함
Clemson, Team 6-5, Benson Spring 2014 Clemson, Team 6-5, Benson Spring 2014 회원
CLEM-BENSON-S14S6G5
3 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 543
