주요 콘텐츠로 건너뛰기
Snapfon ez One Charging Port Replacement
필요한 것
  1. Snapfon ez One Charging Port Replacement, Remove the battery cover: 1 단계, 이미지 1/1
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Snapfon ez One Charging Port Replacement, Remove the battery: 2 단계, 이미지 1/1
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
  3. Snapfon ez One Charging Port Replacement, Removing the plastic inserts: 3 단계, 이미지 1/2 Snapfon ez One Charging Port Replacement, Removing the plastic inserts: 3 단계, 이미지 2/2
    • Remove the four rubber inserts from the screw holes using a pair of tweezers.
  4. Snapfon ez One Charging Port Replacement, Remove the shield screws: 4 단계, 이미지 1/3 Snapfon ez One Charging Port Replacement, Remove the shield screws: 4 단계, 이미지 2/3 Snapfon ez One Charging Port Replacement, Remove the shield screws: 4 단계, 이미지 3/3
    • Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
  5. Snapfon ez One Charging Port Replacement, Separate the case: 5 단계, 이미지 1/3 Snapfon ez One Charging Port Replacement, Separate the case: 5 단계, 이미지 2/3 Snapfon ez One Charging Port Replacement, Separate the case: 5 단계, 이미지 3/3
    • Separate the front case from the back case.
    • Remove the metal bumper from the front case’s perimeter.
  6. Snapfon ez One Charging Port Replacement, Remove the volume slider: 6 단계, 이미지 1/1
    • Pry the volume slider button out with tweezers.
    • The volume slider button may fall out during the separation of the front and back cases. This is OK.
  7. Snapfon ez One Charging Port Replacement, Remove the motherboard: 7 단계, 이미지 1/3 Snapfon ez One Charging Port Replacement, Remove the motherboard: 7 단계, 이미지 2/3 Snapfon ez One Charging Port Replacement, Remove the motherboard: 7 단계, 이미지 3/3
    • Separate the circuit board from the inside of the back case by prying between them with the opening tool.
    • The last picture is a view of the back of the circuit board.
  8. Snapfon ez One Charging Port Replacement, Charging Port: 8 단계, 이미지 1/3 Snapfon ez One Charging Port Replacement, Charging Port: 8 단계, 이미지 2/3 Snapfon ez One Charging Port Replacement, Charging Port: 8 단계, 이미지 3/3
    • Use tweezers to remove the charging port located inside the back cover of the phone.
    • A spudger may be needed to apply pressure with the use of the tweezers for easier removal.
결론
Insert new charging port, and to reassemble your device, follow these instructions in reverse order.
John Bender
회원 가입일: 03/26/14
818 평판
안내서 8개 작성하였습니다
Clemson, Team 6-5, Benson Spring 2014 Clemson, Team 6-5, Benson Spring 2014 회원
CLEM-BENSON-S14S6G5
3 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 293
