주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Snapfon ez One Volume and Unlock switch replacement
필요한 것
  1. Snapfon ez One Volume and Unlock switch replacement, Remove the battery cover: 1 단계, 이미지 1개 중 1개
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Snapfon ez One Volume and Unlock switch replacement, Remove the battery: 2 단계, 이미지 1개 중 1개
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
  3. Snapfon ez One Volume and Unlock switch replacement, Removing the plastic inserts: 3 단계, 이미지 2개 중 1개 Snapfon ez One Volume and Unlock switch replacement, Removing the plastic inserts: 3 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Remove the four rubber inserts from the screw holes using a pair of tweezers.
  4. Snapfon ez One Volume and Unlock switch replacement, Remove the shield screws: 4 단계, 이미지 3개 중 1개 Snapfon ez One Volume and Unlock switch replacement, Remove the shield screws: 4 단계, 이미지 3개 중 2개 Snapfon ez One Volume and Unlock switch replacement, Remove the shield screws: 4 단계, 이미지 3개 중 3개
    • Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
  5. Snapfon ez One Volume and Unlock switch replacement, Separate the case: 5 단계, 이미지 3개 중 1개 Snapfon ez One Volume and Unlock switch replacement, Separate the case: 5 단계, 이미지 3개 중 2개 Snapfon ez One Volume and Unlock switch replacement, Separate the case: 5 단계, 이미지 3개 중 3개
    • Separate the front case from the back case.
    • Remove the metal bumper from the front case’s perimeter.
  6. Snapfon ez One Volume and Unlock switch replacement, Remove the volume slider: 6 단계, 이미지 1개 중 1개
    • Pry the volume slider button out with tweezers.
    • The volume slider button may fall out during the separation of the front and back cases. This is OK.
  7. Snapfon ez One Volume and Unlock switch replacement, Remove the motherboard: 7 단계, 이미지 3개 중 1개 Snapfon ez One Volume and Unlock switch replacement, Remove the motherboard: 7 단계, 이미지 3개 중 2개 Snapfon ez One Volume and Unlock switch replacement, Remove the motherboard: 7 단계, 이미지 3개 중 3개
    • Separate the circuit board from the inside of the back case by prying between them with the opening tool.
    • The last picture is a view of the back of the circuit board.
  8. Snapfon ez One Volume and Unlock switch replacement, Volume and Unlock switch: 8 단계, 이미지 2개 중 1개 Snapfon ez One Volume and Unlock switch replacement, Volume and Unlock switch: 8 단계, 이미지 2개 중 2개
    • All three of these switches (shown in the red boxes in these two pictures) are removed the same way. So this guide will show the removal and repair of only one switch.
    • The button (shown in blue) should already be removed from the disassembly of the circuit board portion of this guide.
  9. Snapfon ez One Volume and Unlock switch replacement: 9 단계, 이미지 3개 중 1개 Snapfon ez One Volume and Unlock switch replacement: 9 단계, 이미지 3개 중 2개 Snapfon ez One Volume and Unlock switch replacement: 9 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to pull the volume button out of the track.
    • Pinch the two sets of clamps together and push outwards (away from the phone) in order to remove the flashlight switch (or either of the other two switches).
  10. Snapfon ez One Volume and Unlock switch replacement: 10 단계, 이미지 3개 중 1개 Snapfon ez One Volume and Unlock switch replacement: 10 단계, 이미지 3개 중 2개 Snapfon ez One Volume and Unlock switch replacement: 10 단계, 이미지 3개 중 3개
    • To remove stickiness or dirt, clean the switch with rubbing alcohol and a brush.
    • Let dry before putting the switch back on the phone.
    • Clean the port with a towel soaked in rubbing alcohol.
    • Finally, let both the port and switch dry before reassembling.
결론
작성자
4다른 기여자 명과 함께
John Bender
회원 가입일: 03/26/14
818 평판
안내서 8개를 작성함
Clemson, Team 6-5, Benson Spring 2014 Clemson, Team 6-5, Benson Spring 2014 회원
CLEM-BENSON-S14S6G5
3 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 53
전체 시간: 1,007
