주요 콘텐츠로 건너뛰기
Snowboard Binding Replacement
필요한 것
  1. Snowboard Binding Replacement, Binding: 1 단계, 이미지 1/3 Snowboard Binding Replacement, Binding: 1 단계, 이미지 2/3 Snowboard Binding Replacement, Binding: 1 단계, 이미지 3/3
    • Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
    • Not all binding straps will release the same way. If you are having trouble releasing your binding straps, please refer to your owner's manual.
  2. Snowboard Binding Replacement: 2 단계, 이미지 1/2 Snowboard Binding Replacement: 2 단계, 이미지 2/2
    • Move the straps and the highback plate out of the way in order to have clear access to the foot pad screw.
    • The highback plate is the vertical support plate located on the heel side of the binding.
  3. Snowboard Binding Replacement: 3 단계, 이미지 1/2 Snowboard Binding Replacement: 3 단계, 이미지 2/2
    • Use a #2 Phillips screwdriver to remove the panhead, 10mm wide, M4 x 12mm screw located in the middle of the foot pad.
  4. Snowboard Binding Replacement: 4 단계, 이미지 1/3 Snowboard Binding Replacement: 4 단계, 이미지 2/3 Snowboard Binding Replacement: 4 단계, 이미지 3/3
    • Use a #2 Phillips screwdriver to remove the four ovalhead M6 x 12mm screws that attach the base plate of the binding to the board.
    • Lift or slide the binding off the board and set the screws aside.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Loren Sunding
회원 가입일: 01/14/14
118 평판
안내서 1개 작성함
Cal Poly, Team 17-4, Forte Winter 2014 Cal Poly, Team 17-4, Forte Winter 2014 회원
CPSU-FORTE-W14S17G4
5 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 12
30일 전: 94
전체 시간: 13,385
