주요 콘텐츠로 건너뛰기
Snowboard Binding Strap Replacement
필요한 것
  1. Snowboard Binding Strap Replacement, Binding: 1 단계, 이미지 3개 중 1개 Snowboard Binding Strap Replacement, Binding: 1 단계, 이미지 3개 중 2개 Snowboard Binding Strap Replacement, Binding: 1 단계, 이미지 3개 중 3개
    • Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
    • Not all binding straps will release the same way. If you are having trouble releasing your binding straps, please refer to your owner's manual.
  2. Snowboard Binding Strap Replacement: 2 단계, 이미지 2개 중 1개 Snowboard Binding Strap Replacement: 2 단계, 이미지 2개 중 2개
    • Move the straps and the highback plate out of the way in order to have clear access to the foot pad screw.
    • The highback plate is the vertical support plate located on the heel side of the binding.
  3. Snowboard Binding Strap Replacement: 3 단계, 이미지 2개 중 1개 Snowboard Binding Strap Replacement: 3 단계, 이미지 2개 중 2개
    • Use a #2 Phillips screwdriver to remove the panhead, 10mm wide, M4 x 12mm screw located in the middle of the foot pad.
  4. Snowboard Binding Strap Replacement: 4 단계, 이미지 3개 중 1개 Snowboard Binding Strap Replacement: 4 단계, 이미지 3개 중 2개 Snowboard Binding Strap Replacement: 4 단계, 이미지 3개 중 3개
    • Use a #2 Phillips screwdriver to remove the four ovalhead M6 x 12mm screws that attach the base plate of the binding to the board.
    • Lift or slide the binding off the board and set the screws aside.
  5. Snowboard Binding Strap Replacement, Binding Strap: 5 단계, 이미지 3개 중 1개 Snowboard Binding Strap Replacement, Binding Strap: 5 단계, 이미지 3개 중 2개 Snowboard Binding Strap Replacement, Binding Strap: 5 단계, 이미지 3개 중 3개
    • Use a 5.5mm flathead screwdriver to anchor the backing bracket located on the inside of the binding.
    • Using a Phillips #2 screwdriver, unscrew the countersunk ovalhead M4 x 16mm screw connecting the heel strap ladder to the binding.
  6. Snowboard Binding Strap Replacement: 6 단계, 이미지 2개 중 1개 Snowboard Binding Strap Replacement: 6 단계, 이미지 2개 중 2개
    • Unscrew the 10mm long thumb screw connecting the heel strap with its binding connector.
    • Pull the heel strap apart from its binding connector.
  7. Snowboard Binding Strap Replacement: 7 단계, 이미지 3개 중 1개 Snowboard Binding Strap Replacement: 7 단계, 이미지 3개 중 2개 Snowboard Binding Strap Replacement: 7 단계, 이미지 3개 중 3개
    • Using a Phillips #2 screwdriver, locate and unscrew the countersunk ovalhead M4 x 16mm screw holding the heel strap connector to the binding.
  8. Snowboard Binding Strap Replacement: 8 단계, 이미지 2개 중 1개 Snowboard Binding Strap Replacement: 8 단계, 이미지 2개 중 2개
    • Flip the binding so that the bottom is accessible.
    • Using your hands, pry off the plastic bottom covering starting at the toe end.
    • The bottom may still remain attached on the heel edge. There is no need to completely remove it.
  9. Snowboard Binding Strap Replacement: 9 단계, 이미지 3개 중 1개 Snowboard Binding Strap Replacement: 9 단계, 이미지 3개 중 2개 Snowboard Binding Strap Replacement: 9 단계, 이미지 3개 중 3개
    • Remove the corner foam coverings by grabbing one edge and lifting up.
    • Slide out the toe strap ladder.
  10. Snowboard Binding Strap Replacement: 10 단계, 이미지 3개 중 1개 Snowboard Binding Strap Replacement: 10 단계, 이미지 3개 중 2개 Snowboard Binding Strap Replacement: 10 단계, 이미지 3개 중 3개
    • Using a Phillips #2 screwdriver, unscrew the button head M4 x 10mm screw holding the toe strap with its connector.
    • Slide the toe strap off of the toe strap connector.
  11. Snowboard Binding Strap Replacement: 11 단계, 이미지 2개 중 1개 Snowboard Binding Strap Replacement: 11 단계, 이미지 2개 중 2개
    • Turn the binding on its side and slide out the toe strap connector.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Robert Torres
회원 가입일: 01/14/14
214 평판
안내서 2개를 작성함
Cal Poly, Team 17-4, Forte Winter 2014 Cal Poly, Team 17-4, Forte Winter 2014 회원
CPSU-FORTE-W14S17G4
5 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 10
지난 7일: 82
지난 30일: 268
전체 시간: 46,978
