주요 콘텐츠로 건너뛰기
SodaStream Fountain Jet A200 CO2 Tank Replacement
필요한 것
  1. SodaStream Fountain Jet A200 CO2 Tank Replacement, CO2 Tank: 1 단계, 이미지 1/2 SodaStream Fountain Jet A200 CO2 Tank Replacement, CO2 Tank: 1 단계, 이미지 2/2
    • Remove the back cover of the device. Press in the two gray buttons found on either side, located at the top of the machine.
    • Pull back on the cover until it releases from the device. Pull the back completely off.
  2. SodaStream Fountain Jet A200 CO2 Tank Replacement: 2 단계, 이미지 1/2 SodaStream Fountain Jet A200 CO2 Tank Replacement: 2 단계, 이미지 2/2
    • Grasp your hand firmly around the CO2 tank and twist it in a clockwise motion.
    • Once the CO2 tank is free, pull it towards you and lift upwards to remove it from the device.
  3. SodaStream Fountain Jet A200 CO2 Tank Replacement, Installing full CO2 tank: 3 단계, 이미지 1/2 SodaStream Fountain Jet A200 CO2 Tank Replacement, Installing full CO2 tank: 3 단계, 이미지 2/2
    • Insert the full CO2 tank up through the hole, located at the bottom of the device.
    • Line up the new CO2 tank with the valve at the top and twist the tank in, using a counter clockwise motion.
  4. SodaStream Fountain Jet A200 CO2 Tank Replacement: 4 단계, 이미지 1/1
    • Line up the small tab on the back cover with its slot near the bottom of the device.
    • Gently push the CO2 tank cover completely back onto the machine.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Katie Fetters
회원 가입일: 09/17/14
815 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 15
30일 전: 53
전체 시간: 12,382
