주요 콘텐츠로 건너뛰기
SodaStream Fountain Jet A200 Spring Replacement
  1. SodaStream Fountain Jet A200 Spring Replacement, removing back cover: 1 단계, 이미지 1/2 SodaStream Fountain Jet A200 Spring Replacement, removing back cover: 1 단계, 이미지 2/2
    • Press in the two gray buttons found on either side, at the top of the machine.
    • Pull back on the cover until it releases from the device and pull the back off.
  2. SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: 2 단계, 이미지 1/2 SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: 2 단계, 이미지 2/2
    • Place your hand under the carbonation button and gently pull up and away from you, towards the back of the machine.
  3. SodaStream Fountain Jet A200 Spring Replacement, spring removal: 3 단계, 이미지 1/2 SodaStream Fountain Jet A200 Spring Replacement, spring removal: 3 단계, 이미지 2/2
    • Remove the spring located under the carbonation button.
    • Replace with the new spring, by lining it up and pushing it down.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Katie Fetters
회원 가입일: 09/17/14
815 평판
안내서 4개 작성하였습니다
댓글 2개
Does anyone know where I can get a carbonation button?
draganr@wi.rr.com
draganr - 답글
Do we know the spring parameters?
Outside Diameter
Inside Diameter
Overall Length
Wire Diameter
Total # of Coils
Active # of Coils
Solid Height
Space between the Coils
John Friedman - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 18
30일 전: 45
전체 시간: 9,908
