이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Push the brass bar, located in the top of the device, out of the carbonating block.
Slide the yellow battery cover up and away to remove it from the device.
Lift the top of the plastic arm with the spudger and remove it on both sides.
Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger.
Pull the loader tab cover down and away from the rest of the carbonating block.
Unhook the four clips on the top of the carbonating block and remove the plastic cover.
Lift the clips located on both sides with the plastic spudger. Slide the front cover off.
Unhook the silver spring arms on both sides of the device by pushing down.
Grip the right and left sides of the device and pull it into two identical halves.
Pull the foam pad up and remove it from the front side of the carbonation component.
Remove the six 17.7 mm screws from the underside of the loader tab piece.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
Bonjour j'ai une pièce à l'intérieur dont je ne retrouve pas du tout la position au remontage.
Pouvez vous m'aider ?
De quelle partie s'agit-il, peux-tu prendre une photo ?
