주요 콘텐츠로 건너뛰기
SodaStream Source Internal Carbonation Air Hose Replacement
필요한 것
  1. SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source External Disassembly: 1 단계, 이미지 3개 중 1개 SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source External Disassembly: 1 단계, 이미지 3개 중 2개 SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source External Disassembly: 1 단계, 이미지 3개 중 3개
    • Remove the soda bottle and the CO₂ canister from the machine.
  2. SodaStream Source Internal Carbonation Air Hose  Replacement: 2 단계, 이미지 2개 중 1개 SodaStream Source Internal Carbonation Air Hose  Replacement: 2 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Phillips #1 Screwdriver
    $8.99
  3. SodaStream Source Internal Carbonation Air Hose  Replacement: 3 단계, 이미지 2개 중 1개 SodaStream Source Internal Carbonation Air Hose  Replacement: 3 단계, 이미지 2개 중 2개
    • Pull the outer cover away from the front of the device.
  4. SodaStream Source Internal Carbonation Air Hose  Replacement: 4 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $8.99
  5. SodaStream Source Internal Carbonation Air Hose  Replacement: 5 단계, 이미지 2개 중 1개 SodaStream Source Internal Carbonation Air Hose  Replacement: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Jimmy
    $7.95
    • Firmly pull the front cover off.
    • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
  6. SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source  Internal Disassembly: 6 단계, 이미지 3개 중 1개 SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source  Internal Disassembly: 6 단계, 이미지 3개 중 2개 SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source  Internal Disassembly: 6 단계, 이미지 3개 중 3개
    • Push the brass bar, located in the top of the device, out of the carbonating block.
    • You can use the end of your screwdriver to push this piece out.
  7. SodaStream Source Internal Carbonation Air Hose  Replacement: 7 단계, 이미지 3개 중 1개 SodaStream Source Internal Carbonation Air Hose  Replacement: 7 단계, 이미지 3개 중 2개 SodaStream Source Internal Carbonation Air Hose  Replacement: 7 단계, 이미지 3개 중 3개
    • Slide the yellow battery cover up and away to remove it from the device.
  8. SodaStream Source Internal Carbonation Air Hose  Replacement: 8 단계, 이미지 2개 중 1개 SodaStream Source Internal Carbonation Air Hose  Replacement: 8 단계, 이미지 2개 중 2개
    • Unhook the bottom piece of the plastic arm on each side of the device.
  9. SodaStream Source Internal Carbonation Air Hose  Replacement: 9 단계, 이미지 2개 중 1개 SodaStream Source Internal Carbonation Air Hose  Replacement: 9 단계, 이미지 2개 중 2개
    • Lift the top of the plastic arm with the spudger and remove it on both sides.
  10. SodaStream Source Internal Carbonation Air Hose  Replacement: 10 단계, 이미지 2개 중 1개 SodaStream Source Internal Carbonation Air Hose  Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger.
  11. SodaStream Source Internal Carbonation Air Hose  Replacement: 11 단계, 이미지 2개 중 1개 SodaStream Source Internal Carbonation Air Hose  Replacement: 11 단계, 이미지 2개 중 2개
    • Remove the plastic oval and the spring within it.
  12. SodaStream Source Internal Carbonation Air Hose  Replacement: 12 단계, 이미지 2개 중 1개 SodaStream Source Internal Carbonation Air Hose  Replacement: 12 단계, 이미지 2개 중 2개
    • Pull the loader tab cover down and away from the rest of the carbonating block.
  13. SodaStream Source Internal Carbonation Air Hose  Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the three 17.9 mm screws located on the right side.
    • These screws may be difficult to access.
  14. SodaStream Source Internal Carbonation Air Hose  Replacement: 14 단계, 이미지 2개 중 1개 SodaStream Source Internal Carbonation Air Hose  Replacement: 14 단계, 이미지 2개 중 2개
    • Unhook the four clips on the top of the carbonating block and remove the plastic cover.
  15. SodaStream Source Internal Carbonation Air Hose  Replacement: 15 단계, 이미지 3개 중 1개 SodaStream Source Internal Carbonation Air Hose  Replacement: 15 단계, 이미지 3개 중 2개 SodaStream Source Internal Carbonation Air Hose  Replacement: 15 단계, 이미지 3개 중 3개
    • Lift the clips located on both sides with the plastic spudger. Slide the front cover off.
  16. SodaStream Source Internal Carbonation Air Hose  Replacement: 16 단계, 이미지 2개 중 1개 SodaStream Source Internal Carbonation Air Hose  Replacement: 16 단계, 이미지 2개 중 2개
    • Unhook the silver spring arms on both sides of the device by pushing down.
  17. SodaStream Source Internal Carbonation Air Hose  Replacement: 17 단계, 이미지 1개 중 1개
    • Grip the right and left sides of the device and pull it into two identical halves.
    • Once these two pieces are apart, all remaining internal components will fall out of the device.
  18. SodaStream Source Internal Carbonation Air Hose  Replacement: 18 단계, 이미지 3개 중 1개 SodaStream Source Internal Carbonation Air Hose  Replacement: 18 단계, 이미지 3개 중 2개 SodaStream Source Internal Carbonation Air Hose  Replacement: 18 단계, 이미지 3개 중 3개
    • Pull the foam pad up and remove it from the front side of the carbonation component.
  19. SodaStream Source Internal Carbonation Air Hose  Replacement: 19 단계, 이미지 1개 중 1개
    • Remove the six 17.7 mm screws from the underside of the loader tab piece.
  20. SodaStream Source Internal Carbonation Air Hose  Replacement: 20 단계, 이미지 3개 중 1개 SodaStream Source Internal Carbonation Air Hose  Replacement: 20 단계, 이미지 3개 중 2개 SodaStream Source Internal Carbonation Air Hose  Replacement: 20 단계, 이미지 3개 중 3개
    • Pull the loader tab out of the nozzle.
  21. SodaStream Source Internal Carbonation Air Hose  Replacement, Internal Carbonation Air Hose: 21 단계, 이미지 2개 중 1개 SodaStream Source Internal Carbonation Air Hose  Replacement, Internal Carbonation Air Hose: 21 단계, 이미지 2개 중 2개
    • Use pliers to unscrew the gold cap piece from both ends of the tube
  22. SodaStream Source Internal Carbonation Air Hose  Replacement: 22 단계, 이미지 3개 중 1개 SodaStream Source Internal Carbonation Air Hose  Replacement: 22 단계, 이미지 3개 중 2개 SodaStream Source Internal Carbonation Air Hose  Replacement: 22 단계, 이미지 3개 중 3개
    • Detach the hose from both sides of the carbonation system.
    • You will have to use force to detach this piece.
결론
다른 23명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Hailey Smith
회원 가입일: 02/20/17
1,432 평판
안내서 2개를 작성함
USF Tampa, Team S1-G4, Leahy Spring 2017 USF Tampa, Team S1-G4, Leahy Spring 2017 회원
USFT-LEAHY-S17S1G4
3 회원들
안내서 41개를 작성함
70가이드 댓글
Thanks for the guide, but i currently have this issue where the hose needs to be replaced, but no way of sourcing a spare part? Any clues anyone?
Nathan Roberts - 답글
Did you ever find the part for your machine?
nagjoinslipknot -
Where would you get this part
magnolia_ca - 답글
Exactly the same problem on my Source, but I can't find spare parts anywhere.
Has anyone found where to get them from in Australia?
nagjoinslipknot - 답글
did you ever find a supplier for the air hose replacement?
mark.jc.wright -
댓글 쓰기
조회 통계:
지난 24시간: 29
지난 7일: 166
지난 30일: 1,148
전체 시간: 76,614
