소개
Sometimes when you operate your SodaStream, the drink does not come out fizzy enough, or you can hear gas escaping on the inside. This may be an issue with the internal air hose. This is a small piece that is part of the inner machine setup. The hose is what helps the carbonation process, it connects the carbonation bottle with the nozzle on the main loader tab, and if it is damaged in any way you may not be able to use your device. In this guide, you will see how the hose can be disconnected and replaced if the need arises.
  1. Remove the soda bottle and the CO2 canister from the machine. Remove the soda bottle and the CO2 canister from the machine. Remove the soda bottle and the CO2 canister from the machine.
    • Remove the soda bottle and the CO2 canister from the machine.
  2. Pull the outer cover away from the front of the device. Pull the outer cover away from the front of the device.
    • Pull the outer cover away from the front of the device.
    • Firmly pull the front cover off.
    • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
  3. Push the gold bar, located in the top of the device, out of the carbonating block. You can use the end of your screwdriver to push this piece out. You can use the end of your screwdriver to push this piece out.
    • Push the gold bar, located in the top of the device, out of the carbonating block.
    • You can use the end of your screwdriver to push this piece out.
  4. Slide the yellow battery cover up and away to remove it from the device. Slide the yellow battery cover up and away to remove it from the device. Slide the yellow battery cover up and away to remove it from the device.
    • Slide the yellow battery cover up and away to remove it from the device.
  5. Unhook the bottom piece of the plastic arm on each side of the device. Unhook the bottom piece of the plastic arm on each side of the device.
    • Unhook the bottom piece of the plastic arm on each side of the device.
  6. 안드로이드 수리 키트
    새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
  7. Lift the top of the plastic arm with the spudger and remove it on both sides. Lift the top of the plastic arm with the spudger and remove it on both sides.
    • Lift the top of the plastic arm with the spudger and remove it on both sides.
  8. Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger. Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger.
    • Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger.
  9. Remove the plastic oval and the spring within it. Remove the plastic oval and the spring within it.
    • Remove the plastic oval and the spring within it.
  10. Pull the loader tab cover down and away from the rest of the carbonating block. Pull the loader tab cover down and away from the rest of the carbonating block.
    • Pull the loader tab cover down and away from the rest of the carbonating block.
  11. Remove the three 17.9 mm screws located on the right side.
    • Remove the three 17.9 mm screws located on the right side.
    • These screws may be difficult to access.
  12. Unhook the four clips on the top of the carbonating block and remove the plastic cover. Unhook the four clips on the top of the carbonating block and remove the plastic cover.
    • Unhook the four clips on the top of the carbonating block and remove the plastic cover.
  13. Lift the clips located on both sides with the plastic spudger. Slide the front cover off. Lift the clips located on both sides with the plastic spudger. Slide the front cover off. Lift the clips located on both sides with the plastic spudger. Slide the front cover off.
    • Lift the clips located on both sides with the plastic spudger. Slide the front cover off.
  14. Unhook the silver spring arms on both sides of the device by pushing down. Unhook the silver spring arms on both sides of the device by pushing down.
    • Unhook the silver spring arms on both sides of the device by pushing down.
  15. Grip the right and left sides of the device and pull it into two identical halves.
    • Grip the right and left sides of the device and pull it into two identical halves.
    • Once these two pieces are apart, all remaining internal components will fall out of the device.
  16. Pull the foam pad up and remove it from the front side of the carbonation component. Pull the foam pad up and remove it from the front side of the carbonation component. Pull the foam pad up and remove it from the front side of the carbonation component.
    • Pull the foam pad up and remove it from the front side of the carbonation component.
  17. Remove the six 17.7 mm screws from the underside of the loader tab piece.
    • Remove the six 17.7 mm screws from the underside of the loader tab piece.
  18. Pull the loader tab out of  the nozzle. Pull the loader tab out of  the nozzle. Pull the loader tab out of  the nozzle.
    • Pull the loader tab out of the nozzle.
  19. Use pliers to unscrew the gold cap piece from both ends of the tube Use pliers to unscrew the gold cap piece from both ends of the tube
    • Use pliers to unscrew the gold cap piece from both ends of the tube
    Where would you get this part?
    Reginaldo Machado - 답글
  20. Detach the hose from both sides of the carbonation system. You will have to use force to detach this piece. You will have to use force to detach this piece.
    • Detach the hose from both sides of the carbonation system.
    • You will have to use force to detach this piece.
    Will it be possible to purchase the air hose?
    evontam - 답글
결론
다른 8명이 해당 안내서를 완성하였습니다.
Hailey Smith
회원 가입일: 2017년 02월 20일
571 Reputation
안내서 2개 작성하였습니다
USF Tampa, Team S1-G4, Leahy Spring 2017 USF Tampa, Team S1-G4, Leahy Spring 2017 회원
USFT-LEAHY-S17S1G4
3 회원들
안내서 9개 작성하였습니다
댓글 17개
Thanks for the guide, but i currently have this issue where the hose needs to be replaced, but no way of sourcing a spare part? Any clues anyone?
Nathan Roberts - 답글
Did you ever find the part for your machine?
nagjoinslipknot -
magnolia_ca - 답글
Exactly the same problem on my Source, but I can't find spare parts anywhere.
Has anyone found where to get them from in Australia?
nagjoinslipknot - 답글
Onde comprar a peça para reposição no Brasil?
I’d also love to find a way to buy this part!
dougsimon - 답글
Any sources for the part? The one I have has a plastic nut that broke.
Jim - 답글
Two things: first, before you disassemble your unit, try this: https://m.youtube.com/watch?v=st4d6drjVe...
Second: It would be _extremely_ useful to have some re-assembly photos. There’s one internal part that’s not shown, and it flew out when I took the halves apart. It’s the thing that fits between the two arms that stick out at the top (and provide the upward force for sliding front of the unit). The part in question has rods that fit into holes in each half, and the smooth, curved side faces toward the front of the unit, just behind the blue thing with the brass pieces.
Mark Pemburn - 답글
That YouTube link is amazing. I think that is probably the issue everyone here actually has.
Thank you.
Matt Lamon - 답글
Like half the comments here, where do you get the hose? The article has links for all the tools but under the 'Parts’ section says None Required! Kinda hard to replace a hose without a replacement!!!
Joseph Miloshevsky - 답글
One of the nut on the hose broke (on my machine, this piece is in plastic instead of metal).
Did someone try to stick the hose directly on the hole? If yes, which glue did you used? Epoxy?
Sébastien Rougier - 답글
Same thing happened to mine. Not even attempting epoxy, as I don’t know anything that would work and seal it due to the compression fitting design. I would simply replace it with what looks like the “update” one with metal tube nuts. The compression fitting is a very small metric one as a 3mm hose and M10x1.0 threads for the nuts
So to reiterate, what’s the P/N for this hose? A replacement guide is useless without being able to get that part.
Tim Spencer -
Is there a place I can purchase the air hose?
evontam - 답글
Same problem here. Can't get the spare part in UK.
Monika Zasadilova - 답글
I need a new nut to Iceland!
Atli Sveinbjörnsson - 답글
Same here. No replacement parts available….
Paul - 답글
Still no source or modification for the delivery hose?
Evan Euphrat - 답글
댓글 쓰기
Past 24 Hours: 12
Past 7 Days: 107
Past 30 Days: 351
All Time: 7,020
