주요 콘텐츠로 건너뛰기
Sol Republic Deck Battery Replacement
필요한 것
  1. Sol Republic Deck Battery Replacement, Battery: 1 단계, 이미지 1/1
    • With plastic spudger wedge in between the top and bottom casings to force sepearation . Exposing the inside components of the Republic Deck.
  2. Sol Republic Deck Battery Replacement: 2 단계, 이미지 1/1
    • Use the screwdriver to unscrew 2 3.63mm Phillips #0 screws securing the plastic plate.
  3. Sol Republic Deck Battery Replacement: 3 단계, 이미지 1/1
    • Remove ribbon cable from the circuit board.
  4. Sol Republic Deck Battery Replacement: 4 단계, 이미지 1/2 Sol Republic Deck Battery Replacement: 4 단계, 이미지 2/2
    • Unscrew five 3.6 mm Phillips #0 screws securing the circuit board.
    • The ribbon cables are adhesive attached to the case, use tweezers to VERY carefully pick them up. They will then lift up with the circuit board. Or desolder them at the bottom to separate from the circuit board.
    • Melt the solder with an iron and used the tweezers to pull the wire upright.
    • You can pull the circuit board up and away from the wires once the wires are pointed up.
  5. Sol Republic Deck Battery Replacement: 5 단계, 이미지 1/1
    • Unscrew eighteen 6.2 mm Phillips #0 screws and lift the black plastic plate from the case.
  6. Sol Republic Deck Battery Replacement: 6 단계, 이미지 1/3 Sol Republic Deck Battery Replacement: 6 단계, 이미지 2/3 Sol Republic Deck Battery Replacement: 6 단계, 이미지 3/3
    • Unscrew both 3.6 mm Phillips #0 screws holding the battery case to the back of the plastic plate.
    • Remove the battery from the battery case.
    • Original battery is ICR18650-30A. Its rated for 3000mAh, 6A continuous (2 C-rate).
결론
다른 4명이 해당 안내서를 완성하였습니다.
Ross Bolton
회원 가입일: 03/21/17
133 평판
안내서 1개 작성함
IUPUI, Team S3-G1, Baechle Spring 2017 IUPUI, Team S3-G1, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S3G1
3 회원들
안내서 3개 작성하였습니다
댓글 10개
I appreciate the battery replacement for the deck,but what about battery replacement
For the deck ultra
chai4i - 답글
What type of battery is it?
Peter Perez - 답글
It's just a regular lithium ion 18650 battery 3.7v 3200-3500 mah. The deck ultra uses 2 of these
Aaron Linn - 답글
The wires which are blue and purple are connected to battery body if im not wrong
vineeth m -
After changing the battery my device is not switching on. Please help. I connected the charger the battery is charging... showing red.
vineeth m - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 20
30일 전: 54
전체 시간: 7,849
