주요 콘텐츠로 건너뛰기
Sol Republic Deck Bluetooth Button Replacement
필요한 것
  1. Sol Republic Deck Bluetooth Button Replacement, Bluetooth Button: 1 단계, 이미지 1/1
    • With plastic spudger wedge in between the top and bottom casings to force sepearation . Exposing the inside components of the Republic Deck.
  2. Sol Republic Deck Bluetooth Button Replacement: 2 단계, 이미지 1/1
    • Use the screwdriver to unscrew two 3.6mm Phillips #0 screws securing the plastic plate.
  3. Sol Republic Deck Bluetooth Button Replacement: 3 단계, 이미지 1/1
    • Remove the ribbon cable from the circuit board.
  4. Sol Republic Deck Bluetooth Button Replacement: 4 단계, 이미지 1/1
    • Plug in de-soldering kit and wait 3 minutes for the solder to heat up.
    • Use the tip of your soldering iron to heat the old solder unit and apply until it melts.
    • Remove speaker wires connecting the speaker to the circuit board.
  5. Sol Republic Deck Bluetooth Button Replacement: 5 단계, 이미지 1/1
    • Unscrew five 3.6 mm Phillips #0 screws securing the circuit board.
  6. Sol Republic Deck Bluetooth Button Replacement: 6 단계, 이미지 1/1
    • Unscrew fifteen 6.2mm Phillips #0 screws and lift the black plastic plate from the case.
  7. Sol Republic Deck Bluetooth Button Replacement: 7 단계, 이미지 1/2 Sol Republic Deck Bluetooth Button Replacement: 7 단계, 이미지 2/2
    • Remove the three 3.6mm Phillips #0 screws.
    • Remove the circuit board containing the BlueTooth button.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jonathan Holtman
회원 가입일: 03/20/17
368 평판
안내서 2개 작성하였습니다
IUPUI, Team S3-G1, Baechle Spring 2017 IUPUI, Team S3-G1, Baechle Spring 2017 회원
IUPUI-BAECHLE-S17S3G1
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 546
