주요 콘텐츠로 건너뛰기
Sol Republic Deck LED Lights Replacement
필요한 것
  1. Sol Republic Deck LED Lights Replacement, LED Lights: 1 단계, 이미지 1/2 Sol Republic Deck LED Lights Replacement, LED Lights: 1 단계, 이미지 2/2
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Insert the tip of a plastic opening tool or spudger into the the middle groove along the edge of the device.
    • Insert another opening tool into the groove to hold the front plate up as you separate both plates on all sides. Use multiple opening tools to keep plates separated if necessary.
  2. Sol Republic Deck LED Lights Replacement: 2 단계, 이미지 1/2 Sol Republic Deck LED Lights Replacement: 2 단계, 이미지 2/2
    • Using a PH00 screwbit, unscrew the two three-tenth cm screws and remove them.
    • Once the screws have been removed, lift the SOL plate revealing the LED Light strip.
  3. Sol Republic Deck LED Lights Replacement: 3 단계, 이미지 1/1
    • Using a PH00 screwbit, unscrew the two three-tenth screws that hold down the LED light strip at both ends.
  4. Sol Republic Deck LED Lights Replacement: 4 단계, 이미지 1/1
    • Using a PH00 screw bit, unscrew the three screws that hold down the motherboard.
  5. Sol Republic Deck LED Lights Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers and fingers to lift tab and ZIF (zero insertion force) connecter.
  6. Sol Republic Deck LED Lights Replacement: 6 단계, 이미지 1/1
    • Once unscrewed, the LED light requiring repair can be accessed by lifting up the entire LED light strip with tweezers.
  7. Sol Republic Deck LED Lights Replacement: 7 단계, 이미지 1/1
    • If you pull the LED light plate too hard, then the motherboard will snap in half.
    • Lift the LED light plate attached to the motherboard off.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Kristina Patel
회원 가입일: 09/24/15
137 평판
안내서 1개 작성함
University of Alabama, Team 1-1, Sydow campbell Fall 2015 University of Alabama, Team 1-1, Sydow campbell Fall 2015 회원
UA-SYDOW CAMPBELL-F15S1G1
5 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 2,097
