소개
There is a play/pause button with an "M" on it located on the front cover of the speaker beneath the letters SOL. This button controls the starting and stopping of the music.
필요한 것
Pry the front face plate from the bottom half of the speaker by inserting the spudger edge into the the middle groove.
Insert another spudger into the middle groove to hold the front plate up as you separate both plates on all sides. Use multiple opening tools to keep plates separated if necessary.
다른 한 분이 해당 안내서를 완성하였습니다.
