주요 콘텐츠로 건너뛰기
Solid-State Drive Replacement in ThinkPad E14 Gen 2 (AMD)
필요한 것
  1. Solid-State Drive Replacement in ThinkPad E14 Gen 2 (AMD), Solid-State Drive: 1 단계, 이미지 1/1
    • Ensure the laptop is powered off.
  2. Solid-State Drive Replacement in ThinkPad E14 Gen 2 (AMD): 2 단계, 이미지 1/3 Solid-State Drive Replacement in ThinkPad E14 Gen 2 (AMD): 2 단계, 이미지 2/3 Solid-State Drive Replacement in ThinkPad E14 Gen 2 (AMD): 2 단계, 이미지 3/3
    • Unscrew all 7 of the Phillips #0 back plate screws on the bottom of the laptop.
    • These will be "captive" and will not come out of the backplate, so you do not need to worry about them getting lost.
    • Separate the back from the laptop assembly using the opening pick tool.
    • If you have trouble with just using one pick tool, feel free to use multiple ones to keep sections of the back plate separated.
  3. Solid-State Drive Replacement in ThinkPad E14 Gen 2 (AMD): 3 단계, 이미지 1/2 Solid-State Drive Replacement in ThinkPad E14 Gen 2 (AMD): 3 단계, 이미지 2/2
    • Unplug the battery connector and press the power button to ensure the device has no power running.
  4. Solid-State Drive Replacement in ThinkPad E14 Gen 2 (AMD): 4 단계, 이미지 1/2 Solid-State Drive Replacement in ThinkPad E14 Gen 2 (AMD): 4 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the single 4 mm screw that secures the solid-state drive.
  5. Solid-State Drive Replacement in ThinkPad E14 Gen 2 (AMD): 5 단계, 이미지 1/3 Solid-State Drive Replacement in ThinkPad E14 Gen 2 (AMD): 5 단계, 이미지 2/3 Solid-State Drive Replacement in ThinkPad E14 Gen 2 (AMD): 5 단계, 이미지 3/3
    • Slide the Solid-State Drive out of its slot.
  6. Solid-State Drive Replacement in ThinkPad E14 Gen 2 (AMD): 6 단계, 이미지 1/3 Solid-State Drive Replacement in ThinkPad E14 Gen 2 (AMD): 6 단계, 이미지 2/3 Solid-State Drive Replacement in ThinkPad E14 Gen 2 (AMD): 6 단계, 이미지 3/3
    • Replace the Solid-State Drive with the new one.
  7. Solid-State Drive Replacement in ThinkPad E14 Gen 2 (AMD): 7 단계, 이미지 1/1
    • Screw in the Solid-State Drive 4 mm Retaining screw in the new Solid-State Drive using the phillips #0 screwdriver.
  8. Solid-State Drive Replacement in ThinkPad E14 Gen 2 (AMD): 8 단계, 이미지 1/1
    • Power the laptop back on to ensure the computer starts up without issues.
결론
A good end of repair practice is to check to make sure that your laptop powers up safely and is able to boot into the new drive that has been installed in your laptop. Following this repair if your Operating System has not been installed, the next step is to install Windows / whichever Operating System you prefer.
Ahmed Alrimawi
회원 가입일: 10/06/22
157 평판
안내서 1개 작성함
University of North Texas, Team 2-3, Raign Fall 2022 University of North Texas, Team 2-3, Raign Fall 2022 회원
UNT-RAIGN-F22S2G3
2 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 26
30일 전: 122
전체 시간: 1,624
