주요 콘텐츠로 건너뛰기
Solio Bolt Battery Replacement
필요한 것
  1. Solio Bolt Battery Replacement, Remove Screw: 1 단계, 이미지 1/1
    • Open the solar panel of the Solio Bolt. Using a philips screwdriver, remove the screw.
  2. Solio Bolt Battery Replacement, Open Case: 2 단계, 이미지 1/1
    • Use a plastic spudger to pry apart the case.
  3. Solio Bolt Battery Replacement, Remove The 'Battery Holder' Assembly: 3 단계, 이미지 1/2 Solio Bolt Battery Replacement, Remove The 'Battery Holder' Assembly: 3 단계, 이미지 2/2
    • Use a philips screwdriver to remove the three screws securing the battery cradle to the device case.
  4. Solio Bolt Battery Replacement, Free Motherboard: 4 단계, 이미지 1/2 Solio Bolt Battery Replacement, Free Motherboard: 4 단계, 이미지 2/2
    • Move the battery slightly, the motherboard can now be lifted from the device case.
  5. Solio Bolt Battery Replacement, Discconnect Battery: 5 단계, 이미지 1/1
    • On the underside of the motherboard, remove the battery lead from its connecting terminal.
결론
Ethel
회원 가입일: 10/29/14
324 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-3, Shastany Fall 2014 UMass Dartmouth, Team 1-3, Shastany Fall 2014 회원
UMASSD-SHASTANY-F14S1G3
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 390
