주요 콘텐츠로 건너뛰기
Solio CLASSIC2 Removing the Circuit Board
필요한 것
  1. Solio CLASSIC2 Removing the Circuit Board, Disconnecting the Battery: 1 단계, 이미지 1개 중 1개
    • Turn off the device by pressing on the clear power button behind the device.
    • To make sure that it is off, make sure the button is not flashing green.
  2. Solio CLASSIC2 Removing the Circuit Board: 2 단계, 이미지 1개 중 1개
    • Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
  3. Solio CLASSIC2 Removing the Circuit Board: 3 단계, 이미지 3개 중 1개 Solio CLASSIC2 Removing the Circuit Board: 3 단계, 이미지 3개 중 2개 Solio CLASSIC2 Removing the Circuit Board: 3 단계, 이미지 3개 중 3개
    • Using the plastic opening tools, gently pry open the side of the large panel.
    • Keeping the tool in, slowly slide the tool along the side of the panel.
  4. Solio CLASSIC2 Removing the Circuit Board: 4 단계, 이미지 2개 중 1개 Solio CLASSIC2 Removing the Circuit Board: 4 단계, 이미지 2개 중 2개
    • Rotate the device 180 degrees.
    • Make sure the opening on other side of the device does not snap closed.
    • Gently slide the plastic opening tool along the side of the panel.
  5. Solio CLASSIC2 Removing the Circuit Board: 5 단계, 이미지 2개 중 1개 Solio CLASSIC2 Removing the Circuit Board: 5 단계, 이미지 2개 중 2개
    • Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel.
    • Using both hands, slowly pull apart the back panel from the rest of the device.
    • Gently flip the back panel open so the circuit board faces up and the two panels are side by side.
  6. Solio CLASSIC2 Removing the Circuit Board: 6 단계, 이미지 2개 중 1개 Solio CLASSIC2 Removing the Circuit Board: 6 단계, 이미지 2개 중 2개
    • Softly pinch the red and blue wires close to the white connector.
    • To pull the wires out, wiggle them back and forth until the connector is fully out.
  7. Solio CLASSIC2 Removing the Circuit Board, Circuit Board: 7 단계, 이미지 1개 중 1개
    • Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
  8. Solio CLASSIC2 Removing the Circuit Board: 8 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
    • Gently lift the circuit board out of the device using tweezers.
결론
작성자
4다른 기여자 명과 함께
Eric Padilla
회원 가입일: 10/21/13
201 평판
안내서 2개를 작성함
Cal Poly, Team 4-28, Amido Fall 2013 Cal Poly, Team 4-28, Amido Fall 2013 회원
CPSU-AMIDO-F13S4G28
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 361
