주요 콘텐츠로 건너뛰기
Solving slow moving ceiling fan with remote control
필요한 것
동영상 개요
  1. Solving slow moving ceiling fan with remote control, Capacitor (depends on brand): 1 단계, 이미지 3개 중 1개 Solving slow moving ceiling fan with remote control, Capacitor (depends on brand): 1 단계, 이미지 3개 중 2개 Solving slow moving ceiling fan with remote control, Capacitor (depends on brand): 1 단계, 이미지 3개 중 3개
    • Specification for capacitor are sometimes printed at the size. This brand uses 0.82uF 275V capacitor. Specification varies with brand.
  2. Solving slow moving ceiling fan with remote control: 2 단계, 이미지 1개 중 1개
    • It will be so much easier if the board can be clamp down using the board repair clamp to hold the board while desoldering the correct capacitor.
  3. Solving slow moving ceiling fan with remote control: 3 단계, 이미지 1개 중 1개
    • Simple suction pump required to remove the molten fuse.
  4. Solving slow moving ceiling fan with remote control: 4 단계, 이미지 1개 중 1개
    • Cut off the excess length using a tiny cutter after a new capacitor is being soldered onto the board.
  5. Solving slow moving ceiling fan with remote control: 5 단계, 이미지 1개 중 1개
    • Test the fan if it is moving at maximum speed after the capacitor is being replaced before assembling it.
결론
Test the board if working before reassembly the circuit board back into the ceiling fan.
작성자
2다른 기여자 명과 함께
SengChoy Liew
회원 가입일: 03/12/12
969 평판
안내서 3개를 작성함
1가이드 댓글
Not worth it, going to trash it & buy simple fan.
Joe W - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 28
전체 시간: 4,677
