주요 콘텐츠로 건너뛰기
Sonim XP5S Dual Sim XP5800 Rugged Cell Phone Battery Replacement
필요한 것
  1. Sonim XP5S Dual Sim XP5800 Rugged Cell Phone Battery Replacement, Battery/SIM/SD replacement: 1 단계, 이미지 1/1
    • Turn the device over to its back
    • Notice the two screws on the back. These are the screws we will need to unscrew.
  2. Sonim XP5S Dual Sim XP5800 Rugged Cell Phone Battery Replacement: 2 단계, 이미지 1/2 Sonim XP5S Dual Sim XP5800 Rugged Cell Phone Battery Replacement: 2 단계, 이미지 2/2
    • After unscrewing them, lift up the protective back shield and put it to the side.
  3. Sonim XP5S Dual Sim XP5800 Rugged Cell Phone Battery Replacement: 3 단계, 이미지 1/2 Sonim XP5S Dual Sim XP5800 Rugged Cell Phone Battery Replacement: 3 단계, 이미지 2/2
    • In the gap at the top of the battery, pull up. This will pull out the battery.
    • Put the battery to the side.
  4. Sonim XP5S Dual Sim XP5800 Rugged Cell Phone Battery Replacement: 4 단계, 이미지 1/1
    • You have removed the battery and gained access to the SD and sim trays.
    • Here you can replace, remove, or insert new SD/sim cards or put a new battery in where the old one was.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Timothy McEvoy
회원 가입일: 01/21/18
1,102 평판
안내서 2개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,540개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 17
전체 시간: 550
