주요 콘텐츠로 건너뛰기
Sonos Connect Top Motherboard Replacement
필요한 것
  1. Sonos Connect Top Motherboard Replacement, WIFI Card: 1 단계, 이미지 1/3 Sonos Connect Top Motherboard Replacement, WIFI Card: 1 단계, 이미지 2/3 Sonos Connect Top Motherboard Replacement, WIFI Card: 1 단계, 이미지 3/3
    • Start by using a spudger or plastic opening tool to remove the bottom cover.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Once enough of the glue is removed, peel the cover off by hand,
  2. Sonos Connect Top Motherboard Replacement: 2 단계, 이미지 1/3 Sonos Connect Top Motherboard Replacement: 2 단계, 이미지 2/3 Sonos Connect Top Motherboard Replacement: 2 단계, 이미지 3/3
    • Remove the four 7.5mm length Philips head screws under the rubber cover.
  3. Sonos Connect Top Motherboard Replacement: 3 단계, 이미지 1/3 Sonos Connect Top Motherboard Replacement: 3 단계, 이미지 2/3 Sonos Connect Top Motherboard Replacement: 3 단계, 이미지 3/3
    • Use a nylon spudger to unsnap the bottom from the sides.
    • Pry until the remaining three points are unsnapped.
    • Once unsnapped, lift the cover.
  4. Sonos Connect Top Motherboard Replacement: 4 단계, 이미지 1/2 Sonos Connect Top Motherboard Replacement: 4 단계, 이미지 2/2
    • Remove the connection for the front buttons to fully remove the cover.
  5. Sonos Connect Top Motherboard Replacement: 5 단계, 이미지 1/2 Sonos Connect Top Motherboard Replacement: 5 단계, 이미지 2/2
    • Use a plastic opening tool or spudger to remove the adhesive covering the the WIFI connectors.
    • Gently pull the wires at the connection point to disconnect them from the motherboard.
  6. Sonos Connect Top Motherboard Replacement: 6 단계, 이미지 1/2 Sonos Connect Top Motherboard Replacement: 6 단계, 이미지 2/2
    • Remove the two pieces of glue holding the WIFI card in place.
  7. Sonos Connect Top Motherboard Replacement: 7 단계, 이미지 1/3 Sonos Connect Top Motherboard Replacement: 7 단계, 이미지 2/3 Sonos Connect Top Motherboard Replacement: 7 단계, 이미지 3/3
    • Scrape the glued pad underneath the WIFI card to seperate the card from the board.
    • Push apart the two clips holding the WIFI card in the connection.
    • Pull the WIFI card out of the connection.
    • When putting the new WIFI card in, put the card in the connector first, then push downward until it clicks.
  8. Sonos Connect Top Motherboard Replacement, Top Motherboard: 8 단계, 이미지 1/1
    • Remove the 7mm length Phillips screw holding the board in place.
  9. Sonos Connect Top Motherboard Replacement: 9 단계, 이미지 1/2 Sonos Connect Top Motherboard Replacement: 9 단계, 이미지 2/2
    • Flip the board over to access the Molex Cable.
  10. Sonos Connect Top Motherboard Replacement: 10 단계, 이미지 1/1
    • Disconnect the Molex Cable from the top motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Clark Snyder
회원 가입일: 01/21/16
483 평판
안내서 4개 작성하였습니다
IUPUI, Team 3-2, Baechle Spring 2016 IUPUI, Team 3-2, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S3G2
4 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 1,921
