주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
If the troubleshooting guide for the WIFI problems hasn't fixed your issue, this guide is for replacing the WIFI card would be suitable to fix the problem.
부품
지정된 부품이 없습니다.
  1. Start by using a spudger or plastic opening tool  to  remove the bottom cover. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible. Once enough of the glue is removed, peel the cover off by hand,
    • Start by using a spudger or plastic opening tool to remove the bottom cover.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
    • Once enough of the glue is removed, peel the cover off by hand,
  2. Remove the four 7.5mm length Philips head screws under the rubber cover. Remove the four 7.5mm length Philips head screws under the rubber cover. Remove the four 7.5mm length Philips head screws under the rubber cover.
    • Remove the four 7.5mm length Philips head screws under the rubber cover.
  3. Use a nylon spudger to unsnap the bottom from the sides. Pry until the remaining three points are unsnapped. Once unsnapped, lift the cover.
    • Use a nylon spudger to unsnap the bottom from the sides.
    • Pry until the remaining three points are unsnapped.
    • Once unsnapped, lift the cover.
  4. Remove the connection for the front buttons to fully remove the cover. Remove the connection for the front buttons to fully remove the cover.
    • Remove the connection for the front buttons to fully remove the cover.
  5. Use a plastic opening tool or spudger to remove the adhesive covering the the WIFI connectors. Gently pull the wires at the connection point to disconnect them from the motherboard.
    • Use a plastic opening tool or spudger to remove the adhesive covering the the WIFI connectors.
    • Gently pull the wires at the connection point to disconnect them from the motherboard.
  6. Remove the two pieces of glue holding the WIFI card in place. Remove the two pieces of glue holding the WIFI card in place.
    • Remove the two pieces of glue holding the WIFI card in place.
  7. Scrape the glued pad underneath the WIFI card to seperate the card from the board. Push apart the two clips holding the WIFI card in the connection. Pull the WIFI card out of the connection.
    • Scrape the glued pad underneath the WIFI card to seperate the card from the board.
    • Push apart the two clips holding the WIFI card in the connection.
    • Pull the WIFI card out of the connection.
    • When putting the new WIFI card in, put the card in the connector first, then push downward until it clicks.
결론
Clark Snyder
회원 가입일: 2016년 01월 21일
434 평판
안내서 4개 작성하였습니다
IUPUI, Team 3-2, Baechle Spring 2016 IUPUI, Team 3-2, Baechle Spring 2016 회원
IUPUI-BAECHLE-S16S3G2
4 회원들
안내서 4개 작성하였습니다
Where do you source the replacement wifi card?
cterrell9 - 답글
great piece of advice. After some searching I found this on ebay.
https://www.ebay.co.uk/itm/Atheros-AR500...
or type in search bar Atheros AR5008 AR5416 Mini PCI N 802.11N 300M WIFI Wireless Card Dell ASUS SONY.
It cost me around £10.00 and seems to be working fine now after installation
Garry Briggs - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 26
30일 전: 103
전체 시간: 2,176
