소개
This guide is for the replacement of the control panel and microphones for the Sonos One.
Disconnect all power cords.
Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
