주요 콘텐츠로 건너뛰기
Sonos One Mid-Woofer Diaphragm Repair/ Replacement
필요한 것
  1. Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Protective Cover: 1 단계, 이미지 3개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Protective Cover: 1 단계, 이미지 3개 중 2개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Protective Cover: 1 단계, 이미지 3개 중 3개
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
  2. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 2 단계, 이미지 3개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 2 단계, 이미지 3개 중 2개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
  3. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 3 단계, 이미지 2개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 3 단계, 이미지 2개 중 2개
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
  4. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 4 단계, 이미지 3개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 4 단계, 이미지 3개 중 2개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 4 단계, 이미지 3개 중 3개
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
  5. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 5 단계, 이미지 2개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 5 단계, 이미지 2개 중 2개
    • Slide the protective cover upwards to remove.
  6. Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Control Panel & Microphone: 6 단계, 이미지 3개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Control Panel & Microphone: 6 단계, 이미지 3개 중 2개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Control Panel & Microphone: 6 단계, 이미지 3개 중 3개
    • Use the pointed end of a spudger to remove the covers that hide the screws.
    • Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
  7. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 7 단계, 이미지 2개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 7 단계, 이미지 2개 중 2개
    • With the front of the unit facing you, lift the control panel up using your thumbs.
    • There's a ribbon cable attaching the control panel to the speaker so work slowly.
  8. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 8 단계, 이미지 3개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 8 단계, 이미지 3개 중 2개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 8 단계, 이미지 3개 중 3개
    • Use a spudger to flip up the retaining flap on the control panel ribbon cable ZIF socket.
    • Pull the control panel ribbon cable out of its socket.
  9. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 9 단계, 이미지 2개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 9 단계, 이미지 2개 중 2개
    • Pull the control panel away from the speaker to separate.
  10. Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Power Adapter Receptacle: 10 단계, 이미지 3개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Power Adapter Receptacle: 10 단계, 이미지 3개 중 2개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Power Adapter Receptacle: 10 단계, 이미지 3개 중 3개
    • Remove the six 9mm Torx T8 screws from the motherboard panel.
  11. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 11 단계, 이미지 2개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 11 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, separate the motherboard from the speaker.
  12. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 12 단계, 이미지 3개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 12 단계, 이미지 3개 중 2개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 12 단계, 이미지 3개 중 3개
    • Using your thumb, disconnect the speaker cable from the motherboard.
  13. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 13 단계, 이미지 3개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 13 단계, 이미지 3개 중 2개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 13 단계, 이미지 3개 중 3개
    • Disconnect the power adapter plug from the motherboard using your thumb.
  14. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 14 단계, 이미지 3개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 14 단계, 이미지 3개 중 2개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 14 단계, 이미지 3개 중 3개
    • Using the pointed end of the spudger, disconnect the red, green, and yellow cables connecting the WiFi transmitter/receiver.
  15. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 15 단계, 이미지 2개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 15 단계, 이미지 2개 중 2개
    • Remove the motherboard panel from the speaker housing.
  16. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 16 단계, 이미지 3개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 16 단계, 이미지 3개 중 2개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 16 단계, 이미지 3개 중 3개
    • The woofer is highly magnetic, making removal of the metal screws sometimes difficult.
    • Remove the two 9mm Torx T8 screws from the power adapter plug.
    • Remove the power adapter receptacle from its housing slot.
  17. Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Tweeter Diaphragm: 17 단계, 이미지 3개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Tweeter Diaphragm: 17 단계, 이미지 3개 중 2개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Tweeter Diaphragm: 17 단계, 이미지 3개 중 3개
    • Disconnect the woofer cables.
    • If removing the tabs is difficult, the flat end of the spudger may be used to depress the middle tab and then the tab may be pulled to disconnect.
  18. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 18 단계, 이미지 3개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 18 단계, 이미지 3개 중 2개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 18 단계, 이미지 3개 중 3개
    • Disconnect the cables from the tweeter.
  19. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 19 단계, 이미지 3개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 19 단계, 이미지 3개 중 2개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 19 단계, 이미지 3개 중 3개
    • Remove the four 10mm Torx T10 screws from the tweeter.
    • Remove the tweeter from the speaker housing.
  20. Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Woofer Diaphragm: 20 단계, 이미지 3개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Woofer Diaphragm: 20 단계, 이미지 3개 중 2개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement, Woofer Diaphragm: 20 단계, 이미지 3개 중 3개
    • Remove the four 10mm Torx T10 screws from the woofer.
  21. Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 21 단계, 이미지 3개 중 1개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 21 단계, 이미지 3개 중 2개 Sonos One Mid-Woofer Diaphragm Repair/ Replacement: 21 단계, 이미지 3개 중 3개
    • The woofer is snuggly fit into the frame socket, some careful manipulation is required to remove the woofer from the housing.
    • Remove the woofer from the speaker housing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Marcus Glowa
회원 가입일: 02/14/18
1,064 평판
안내서 5개를 작성함
USF Tampa, Team S2-G1, Nance Spring 2018 USF Tampa, Team S2-G1, Nance Spring 2018 회원
USFT-NANCE-S18S2G1
3 회원들
안내서 14개를 작성함
5가이드 댓글
Any suggestion on where to buy these woofers (in Europe/Belgium)?
KimVM - 답글
@mglowa Any idea where to buy a replacement woofer pictured above? Or what to look for, an equivalent perhaps?
Bryan Martinez - 답글
This is the link to the replacement woofer that I used to repair my Sonos One in August 2024: https://www.aliexpress.com/item/10050071...
robotedward - 답글
"SOTAMIA 1Pcs 3.5 Inch Midrange Woofer Speaker 4 Ohm 35W Bass Loudspeaker Aluminum Basin Hifi Music Sound Speaker Audio For SONOS"
56mm high,
75mm distance between adjacent screw holes
105mm diagonal distance between non-adjacent screw holes
97mm width of outer casing
robotedward - 답글
Great guide - replaced the subwoofer using the part above. A few things to note:
Step 13: my unit didn't have an power adapter plug; wires soldered onto board
Step 14:my unit had hardened glue spread on the yellow/red/green cables making removal impossible.
There was no need to remove the tweeter to replace the woofer (steps 18/19).
markrwhite - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 134
전체 시간: 8,404
