소개
This guide is for the replacement of the woofer diaphragm for the Sonos One.
Important: Accessing the internals of the Sonos One will void the factory warranty and make the unit rejected for factory repair, even if warranty is expired.
필요한 것
Disconnect all power cords.
Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
Remove the four 9mm Torx T8 screws from around the perimeter of the control panel.
Using the pointed end of the spudger, disconnect the red, green, and yellow cables connecting the WiFi transmitter/receiver.
These terminals were covered with a big glob of wax on my motherboard, so I managed to remove the woofer without detaching the motherboard from the speaker housing. So, this step is optional, and really isn’t necessary.
Disconnect the cables from the tweeter.
Remove the four 10mm Torx T10 screws from the tweeter.
Remove the tweeter from the speaker housing.
Remove the four 10mm Torx T10 screws from the woofer.
댓글 2개
@mglowa Any idea where to buy a replacement woofer pictured above? Or what to look for, an equivalent perhaps?
