주요 콘텐츠로 건너뛰기
Sonos One Protective Cover Replacement
필요한 것
  1. Sonos One Protective Cover Replacement, Protective Cover: 1 단계, 이미지 1/3 Sonos One Protective Cover Replacement, Protective Cover: 1 단계, 이미지 2/3 Sonos One Protective Cover Replacement, Protective Cover: 1 단계, 이미지 3/3
    • Disconnect all power cords.
    • Remove the rubber foot and plastic screw guard on the bottom of the device using a plastic opening tool.
    • Note: the rubber foot and plastic screw guard can be removed as one piece to make reassembly easier
  2. Sonos One Protective Cover Replacement: 2 단계, 이미지 1/3 Sonos One Protective Cover Replacement: 2 단계, 이미지 2/3 Sonos One Protective Cover Replacement: 2 단계, 이미지 3/3
    • Remove the four 10mm Torx T10 screws from the bottom of the speaker.
    More specifics on the four 10mm Torx T10 screws at the bottom, step 2.
    ex: M3
    Thanks
    J Pappas - 답글
  3. Sonos One Protective Cover Replacement: 3 단계, 이미지 1/2 Sonos One Protective Cover Replacement: 3 단계, 이미지 2/2
    • Remove the bottom cover by squeezing the protective cover slightly while pushing up with your fingers.
  4. Sonos One Protective Cover Replacement: 4 단계, 이미지 1/3 Sonos One Protective Cover Replacement: 4 단계, 이미지 2/3 Sonos One Protective Cover Replacement: 4 단계, 이미지 3/3
    • The protective cover clip is very thin and deforms easily.
    • Remove the single 8mm Torx T10 screw and protective cover clip.
  5. Sonos One Protective Cover Replacement: 5 단계, 이미지 1/2 Sonos One Protective Cover Replacement: 5 단계, 이미지 2/2
    • Slide the protective cover upwards to remove.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Marcus Glowa
회원 가입일: 02/14/18
848 평판
안내서 5개 작성하였습니다
USF Tampa, Team S2-G1, Nance Spring 2018 USF Tampa, Team S2-G1, Nance Spring 2018 회원
USFT-NANCE-S18S2G1
3 회원들
안내서 6개 작성하였습니다
댓글 한 개
Well done! I would add a little bit about how much adhesive there is underneath the rubber feet as well as the screw cover.
Joshua Pinter - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 15
30일 전: 60
전체 시간: 4,618
