주요 콘텐츠로 건너뛰기
Sonos Play 3 Mid-Range Speakers Replacement
필요한 것
  1. Sonos Play 3 Mid-Range Speakers Replacement, Speaker Grille: 1 단계, 이미지 1/2 Sonos Play 3 Mid-Range Speakers Replacement, Speaker Grille: 1 단계, 이미지 2/2
    • Insert a spudger along the edge of the screen and gently use it to pull the screen away from the casing. Slide the spudger along the length of the grill to detach all the clips holding it in place.
  2. Sonos Play 3 Mid-Range Speakers Replacement: 2 단계, 이미지 1/1
    • Gently pull the screen away from the body of the speaker, revealing the tweeter and two mid-range drivers behind it.
    • There may be a kind of black sticky adhesive holding the screen clips to the rest of the body; however, it was previously removed on our model.
  3. Sonos Play 3 Mid-Range Speakers Replacement, Front Speaker Panel: 3 단계, 이미지 1/2 Sonos Play 3 Mid-Range Speakers Replacement, Front Speaker Panel: 3 단계, 이미지 2/2
    • Unscrew eight 1.5 inch Phillips #2 screws attaching the front speaker panel to the box.
    • Unscrew the single 1 inch Phillips #2 screw located on the left side of the panel. This may be hidden beneath the warranty void sticker that you'll want to remove.
    • Unscrew the single 3/4 inch Phillips #2 screw, which is the last thing holding the front panel to the casing.
  4. Sonos Play 3 Mid-Range Speakers Replacement: 4 단계, 이미지 1/3 Sonos Play 3 Mid-Range Speakers Replacement: 4 단계, 이미지 2/3 Sonos Play 3 Mid-Range Speakers Replacement: 4 단계, 이미지 3/3
    • Remove the front panel carefully.
    • Note that there are two layers to the panel that should stay in their original order.
  5. Sonos Play 3 Mid-Range Speakers Replacement: 5 단계, 이미지 1/2 Sonos Play 3 Mid-Range Speakers Replacement: 5 단계, 이미지 2/2
    • Disconnect the front panel from the motherboard by gently reaching in and pushing the tab underneath the wire connector and pulling towards you.
  6. Sonos Play 3 Mid-Range Speakers Replacement: 6 단계, 이미지 1/2 Sonos Play 3 Mid-Range Speakers Replacement: 6 단계, 이미지 2/2
    • Gently remove the wireless card located at the bottom of the front speaker panel by pulling up and out with your index finger and thumb.
  7. Sonos Play 3 Mid-Range Speakers Replacement, Mid-Range Speakers: 7 단계, 이미지 1/3 Sonos Play 3 Mid-Range Speakers Replacement, Mid-Range Speakers: 7 단계, 이미지 2/3 Sonos Play 3 Mid-Range Speakers Replacement, Mid-Range Speakers: 7 단계, 이미지 3/3
    • Use tweezers to disconnect the wire connectors from the mid-range speakers. The connectors may be very tight, but we promise they do come off.
  8. Sonos Play 3 Mid-Range Speakers Replacement: 8 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, remove the screws securing the speakers to the front panel.
  9. Sonos Play 3 Mid-Range Speakers Replacement: 9 단계, 이미지 1/2 Sonos Play 3 Mid-Range Speakers Replacement: 9 단계, 이미지 2/2
    • Carefully lift the speaker you need to replace out the front of the panel.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Christina Santini
회원 가입일: 04/14/16
1,350 평판
안내서 7개 작성하였습니다
Cal Poly, Team 25-6, Maness Spring 2016 Cal Poly, Team 25-6, Maness Spring 2016 회원
CPSU-MANESS-S16S25G6
4 회원들
안내서 14개 작성하였습니다
댓글 6개
What’s the point of taking the speaker out, if I can’t buy a replacement?
Peter - 답글
hi! where can i buy a replacement speaker?
Kareem - 답글
Christina, where did you get the replacement speaker??? What is the point of the how to without the parts??
wedevets - 답글
Dove posso trovare i ricambi sonos
Giustino - 답글
Successful driver replacement !
I dropped my Play 3 about a month ago. Both of the mid range drivers suffered damage. The magnets pulled the cones off center. I was able to reset one of the cones and it tested ok. The other unit not so much. I bought 2 drivers from AliExpress, deciding to replace both anyway . They arrived in 3 weeks, fit perfectly in the enclosure and the wire connectors needed no mods either. The replacements took about 10-15 minutes to install and the Play 3 is now playing beautifully! Link for the drivers:
https://www.aliexpress.com/item/22518326...
Doug Field - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 36
전체 시간: 4,844
