주요 콘텐츠로 건너뛰기
Sonos Play 3 Motherboard Replacement
필요한 것
  1. Sonos Play 3 Motherboard Replacement, Speaker Grille: 1 단계, 이미지 1/2 Sonos Play 3 Motherboard Replacement, Speaker Grille: 1 단계, 이미지 2/2
    • Insert a spudger along the edge of the screen and gently use it to pull the screen away from the casing. Slide the spudger along the length of the grill to detach all the clips holding it in place.
  2. Sonos Play 3 Motherboard Replacement: 2 단계, 이미지 1/1
    • Gently pull the screen away from the body of the speaker, revealing the tweeter and two mid-range drivers behind it.
    • There may be a kind of black sticky adhesive holding the screen clips to the rest of the body; however, it was previously removed on our model.
  3. Sonos Play 3 Motherboard Replacement, Front Speaker Panel: 3 단계, 이미지 1/2 Sonos Play 3 Motherboard Replacement, Front Speaker Panel: 3 단계, 이미지 2/2
    • Unscrew eight 1.5 inch Phillips #2 screws attaching the front speaker panel to the box.
    • Unscrew the single 1 inch Phillips #2 screw located on the left side of the panel. This may be hidden beneath the warranty void sticker that you'll want to remove.
    • Unscrew the single 3/4 inch Phillips #2 screw, which is the last thing holding the front panel to the casing.
  4. Sonos Play 3 Motherboard Replacement: 4 단계, 이미지 1/3 Sonos Play 3 Motherboard Replacement: 4 단계, 이미지 2/3 Sonos Play 3 Motherboard Replacement: 4 단계, 이미지 3/3
    • Remove the front panel carefully.
    • Note that there are two layers to the panel that should stay in their original order.
  5. Sonos Play 3 Motherboard Replacement: 5 단계, 이미지 1/2 Sonos Play 3 Motherboard Replacement: 5 단계, 이미지 2/2
    • Disconnect the front panel from the motherboard by gently reaching in and pushing the tab underneath the wire connector and pulling towards you.
  6. Sonos Play 3 Motherboard Replacement: 6 단계, 이미지 1/2 Sonos Play 3 Motherboard Replacement: 6 단계, 이미지 2/2
    • Gently remove the wireless card located at the bottom of the front speaker panel by pulling up and out with your index finger and thumb.
  7. Sonos Play 3 Motherboard Replacement, Motherboard: 7 단계, 이미지 1/2 Sonos Play 3 Motherboard Replacement, Motherboard: 7 단계, 이미지 2/2
    • Disconnect the motherboard from the power supply board by gently reaching in and pushing the tab underneath the wire connector and pulling towards you.
  8. Sonos Play 3 Motherboard Replacement: 8 단계, 이미지 1/2 Sonos Play 3 Motherboard Replacement: 8 단계, 이미지 2/2
    • Disconnect the motherboard from the volume button board by gently grabbing the connector and pulling it towards you.
  9. Sonos Play 3 Motherboard Replacement: 9 단계, 이미지 1/1
    • Using a Phillips #2 screwdriver, remove the 4 screws securing the two plastic panels down.
  10. Sonos Play 3 Motherboard Replacement: 10 단계, 이미지 1/2 Sonos Play 3 Motherboard Replacement: 10 단계, 이미지 2/2
    • Remove the two plastic panels on either side of the device that hold the motherboard and power supply board in place.
  11. Sonos Play 3 Motherboard Replacement: 11 단계, 이미지 1/1
    • Using a Phillips screwdriver, unscrew the two screws in the back of the device that hold the motherboard in place.
  12. Sonos Play 3 Motherboard Replacement: 12 단계, 이미지 1/3 Sonos Play 3 Motherboard Replacement: 12 단계, 이미지 2/3 Sonos Play 3 Motherboard Replacement: 12 단계, 이미지 3/3
    • Gently remove the motherboard from the Sonos device by sliding it straight back towards you.
    • When putting the motherboard back inside the device, make sure it slides in the slots smoothly on both sides.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Christina Santini
회원 가입일: 04/14/16
1,350 평판
안내서 7개 작성하였습니다
Cal Poly, Team 25-6, Maness Spring 2016 Cal Poly, Team 25-6, Maness Spring 2016 회원
CPSU-MANESS-S16S25G6
4 회원들
안내서 14개 작성하였습니다
댓글 한 개
Where can I buy a new power board?
Roger Beasley - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 39
전체 시간: 4,548
