주요 콘텐츠로 건너뛰기
Sonos Play 5 Mid- Range Speakers Replacement
필요한 것
  1. Sonos Play 5 Mid- Range Speakers Replacement, Front Panel Assembly: 1 단계, 이미지 1/1
    • Disconnect any power to the speaker and wait a few minutes for the capacitors to fully discharge.
    • Flip the speaker upside down.
    • There may be a rubber foot covering the bottom screws (not included in picture). Remove this by pulling up from one of the corners using a spudger.
  2. Sonos Play 5 Mid- Range Speakers Replacement: 2 단계, 이미지 1/2 Sonos Play 5 Mid- Range Speakers Replacement: 2 단계, 이미지 2/2
    • Remove eight 10mm Phillips #2 screws
    • Remove the bottom panel by pulling upwards.
    • Be very gentle with the ends of the three antennas. They are very fragile.
  3. Sonos Play 5 Mid- Range Speakers Replacement: 3 단계, 이미지 1/3 Sonos Play 5 Mid- Range Speakers Replacement: 3 단계, 이미지 2/3 Sonos Play 5 Mid- Range Speakers Replacement: 3 단계, 이미지 3/3
    • Flip the device so that the grille is facing up.
    • Locate the line on the right side of the speaker where the grill and the plastic meet, and place your plastic opening tool in the gap.
    • Run the spudger along the gap, loosening the grille from the plastic. Repeat this process on the left side as well.
    • Gently pull up on the grille, removing it from the front panel.
  4. Sonos Play 5 Mid- Range Speakers Replacement: 4 단계, 이미지 1/1
    • Remove the six 8mm Phillips #2 screws.
    • Remove the two 10mm Phillips #2 screws.
  5. Sonos Play 5 Mid- Range Speakers Replacement: 5 단계, 이미지 1/2 Sonos Play 5 Mid- Range Speakers Replacement: 5 단계, 이미지 2/2
    • Locate the line on the right side where the front panel and back panel meet. Place a plastic opening tool in the gap, and run it along the gap. Repeat this on the left side.
    • Use the opening tool to lift the front plate. If a plastic tool is not providing enough leverage, use a metal opening tool.
    • Gently pull up on the face plate to ensure it has been detached from the enclosure.
    • When pulling on the face plate be cautious because it is still connected by wires on the back of the plate.
  6. Sonos Play 5 Mid- Range Speakers Replacement: 6 단계, 이미지 1/3 Sonos Play 5 Mid- Range Speakers Replacement: 6 단계, 이미지 2/3 Sonos Play 5 Mid- Range Speakers Replacement: 6 단계, 이미지 3/3
    • Lift up the front panel, forming a 90 degree angle with the back panel. Locate the locate ten pin connector shown. This is the wire that connects the front panel to back panel.
    • Press down on the small tab located on the connector. With the tab firmly pressed down, pull the connector out from its socket.
    • The faceplate assembly is now fully detached from the rest of the speaker.
  7. Sonos Play 5 Mid- Range Speakers Replacement, Mid- Range Speakers: 7 단계, 이미지 1/2 Sonos Play 5 Mid- Range Speakers Replacement, Mid- Range Speakers: 7 단계, 이미지 2/2
    • Remove four 9.5mm Phillips #2 screws.
  8. Sonos Play 5 Mid- Range Speakers Replacement: 8 단계, 이미지 1/1
  9. Sonos Play 5 Mid- Range Speakers Replacement: 9 단계, 이미지 1/2 Sonos Play 5 Mid- Range Speakers Replacement: 9 단계, 이미지 2/2
    • Unplug the wires connected to the left speaker.
  10. Sonos Play 5 Mid- Range Speakers Replacement: 10 단계, 이미지 1/1
    • Pull the left speaker up and away from the front panel.
  11. Sonos Play 5 Mid- Range Speakers Replacement: 11 단계, 이미지 1/2 Sonos Play 5 Mid- Range Speakers Replacement: 11 단계, 이미지 2/2
    • Remove the wires from the plastic clips on the bottom of the front panel.
  12. Sonos Play 5 Mid- Range Speakers Replacement: 12 단계, 이미지 1/1
  13. Sonos Play 5 Mid- Range Speakers Replacement: 13 단계, 이미지 1/1
    • Remove the plastic speaker cover by lifting up and away.
  14. Sonos Play 5 Mid- Range Speakers Replacement: 14 단계, 이미지 1/1
  15. Sonos Play 5 Mid- Range Speakers Replacement: 15 단계, 이미지 1/1
    • Remove the right mid-range speaker buy pulling up and away from the front panel.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Warren Girouard
회원 가입일: 02/20/17
309 평판
안내서 2개 작성하였습니다
USF Tampa, Team S3-G6, Sullivan Spring 2017 USF Tampa, Team S3-G6, Sullivan Spring 2017 회원
USFT-SULLIVAN-S17S3G6
4 회원들
안내서 16개 작성하였습니다
댓글 한 개
Thanks for posting this howto on the SonosPlay5.
I have a unit with a broken midrange speaker that needs replacing - do you have any idea where I might purchase one of these please?
Gerry - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 33
전체 시간: 4,778
