소개
This guide will instruct you on how to replace your subwoofer. Keep in mind that the backs of the subwoofer are magnetic, so when working, keep them away from any devices that may be harmed by exposure to magnets.
필요한 것
Disconnect any power to the speaker and wait a few minutes for the capacitors to fully discharge.
Flip the speaker upside down.
Flip the device so that the grille is facing up.
Locate the line on the right side of the speaker where the grill and the plastic meet, and place your plastic opening tool in the gap.
Run the spudger along the gap, loosening the grille from the plastic. Repeat this process on the left side as well.
Gently pull up on the grille, removing it from the front panel.
Locate the line on the right side where the front panel and back panel meet. Place a plastic opening tool in the gap, and run it along the gap. Repeat this on the left side.
Use the opening tool to lift the front plate. If a plastic tool is not providing enough leverage, use a metal opening tool.
Gently pull up on the face plate to ensure it has been detached from the enclosure.
Lift up the front panel, forming a 90 degree angle with the back panel. Locate the locate ten pin connector shown. This is the wire that connects the front panel to back panel.
Press down on the small tab located on the connector. With the tab firmly pressed down, pull the connector out from its socket.
The faceplate assembly is now fully detached from the rest of the speaker.
Locate the red and black wires connected to the subwoofer.
Disconnect the red and black wires by pulling gently on the rubber ends attached to the connectors.
다른 2명이 해당 안내서를 완성하였습니다.
댓글 3개
Hei,
Tnx for nice and useful instruction.
Where do we buy spare sub ?
Brg Frank
Where can you buy the speaker parts?
https://www.olx.ua/obyavlenie/odin-dinam...
i can buy in this store
