주요 콘텐츠로 건너뛰기
Sonos Playbase IR Reciver Replacement
필요한 것
  1. Sonos Playbase IR Reciver Replacement, Bottom Panel: 1 단계, 이미지 1/3 Sonos Playbase IR Reciver Replacement, Bottom Panel: 1 단계, 이미지 2/3 Sonos Playbase IR Reciver Replacement, Bottom Panel: 1 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Pro Tech Toolkit
    $74.95
    구매
    • Turn the Playbase upside down so that the "Sonos Playbase" imprint is face up.
    • Remove the bottom panel with an Opening Tool by inserting underneath and prying upwards.
    • Melt the adhesive with an iOpener for ease of opening
    • Use a Metal Spudger if the plastic spudgers do not work.
    • Take care to avoid damaging the plastic or the device if using a metal spudger.
  2. Sonos Playbase IR Reciver Replacement: 2 단계, 이미지 1/2 Sonos Playbase IR Reciver Replacement: 2 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Pro Tech Toolkit
    $74.95
    구매
    • Remove the fourteen 11mm T-10 screws by turning counter-clockwise.
    • Remove the seven 44mm T-20 screws by turning counter-clockwise.
    • Remove the twenty-two 34mm T-20 screws by turning counter-clockwise.
    • Record where each screw belongs for easier reassembly.
  3. Sonos Playbase IR Reciver Replacement: 3 단계, 이미지 1/2 Sonos Playbase IR Reciver Replacement: 3 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Pro Tech Toolkit
    $74.95
    구매
    • Remove the metal plate with a Opening Tool by inserting underneath and prying upwards.
    • Use a metal spudger if plastic openers do not work.
  4. Sonos Playbase IR Reciver Replacement, Main Speaker Array: 4 단계, 이미지 1/2 Sonos Playbase IR Reciver Replacement, Main Speaker Array: 4 단계, 이미지 2/2
  5. Sonos Playbase IR Reciver Replacement: 5 단계, 이미지 1/2 Sonos Playbase IR Reciver Replacement: 5 단계, 이미지 2/2
    • Remove the side speakers from the green printed circuit board (PCB) running along the top of the main speaker array by pinching and pulling out the connector.
    • See Recognizing & Disconnecting Cable Connectors for more information.
  6. Sonos Playbase IR Reciver Replacement: 6 단계, 이미지 1/3 Sonos Playbase IR Reciver Replacement: 6 단계, 이미지 2/3 Sonos Playbase IR Reciver Replacement: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Pro Tech Toolkit
    $74.95
    구매
    • Remove the two 16mm T-20 screws located on both sides of the main speaker array by turning counter-clockwise.
  7. Sonos Playbase IR Reciver Replacement: 7 단계, 이미지 1/1
    • Remove the main speaker array by gripping it on both sides and pulling it out.
    • The array may require a significant amount of force to remove.
    • Use prying tools as necessary to remove the main speaker array if you are unsuccessful using your hands.
    • Do not to yank the array out too suddenly or too far as this may damage the device.
  8. Sonos Playbase IR Reciver Replacement: 8 단계, 이미지 1/1
    • Prop the removed main speaker array up on top of the main circuit board.
  9. Sonos Playbase IR Reciver Replacement, IR Receiver: 9 단계, 이미지 1/3 Sonos Playbase IR Reciver Replacement, IR Receiver: 9 단계, 이미지 2/3 Sonos Playbase IR Reciver Replacement, IR Receiver: 9 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Pro Tech Toolkit
    $74.95
    구매
    • Lift the main speaker array to reveal the IR receiver underneath.
    • Remove the three 11 mm T-5 screws by turning counter-clockwise.
  10. Sonos Playbase IR Reciver Replacement: 10 단계, 이미지 1/3 Sonos Playbase IR Reciver Replacement: 10 단계, 이미지 2/3 Sonos Playbase IR Reciver Replacement: 10 단계, 이미지 3/3
  11. Sonos Playbase IR Reciver Replacement: 11 단계, 이미지 1/2 Sonos Playbase IR Reciver Replacement: 11 단계, 이미지 2/2
    • Remove the IR receiver by grasping it with two fingers and pulling up.
결론
George Slivka
회원 가입일: 10/08/18
339 평판
안내서 3개 작성하였습니다
Cal Poly, Team S17-G2, White Fall 2018 Cal Poly, Team S17-G2, White Fall 2018 회원
CPSU-WHITE-F18S17G2
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 13
전체 시간: 1,099
